Thread: JET ECU Upgrade with A/T?
Showing results 1 to 16 of 16
    I was thinking about sending ECU off to JET for them to chip the ECU. I have an a/t so I was thinking it would be better since I dont plan on going 5spd. Tractix wont work either...I have a 2002 4g64 Es galant. If I told Jet What to tune at and how much retard on igniiton timming, and AFR, and many others. will it work out...? I have seen alot of people say bad things but feed back from people were always N/A...what do you guys think...
    2001+ ecu's will work with ecuflash. JET will do nothing for you. Please search...
    I'm an 02 and I'm flashed
    are you boosted?
    Quote Originally Posted by airborneparainf82 View Post
    You are? if you aren't boosted I dont think it will do much good.....
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
    Quote Originally Posted by Ivory8g View Post
    no, and yeah its nothing huge, but it was a noticable difference with all the other little gains added in with part upgrades. mainly i noticed an increase in fuel economy. the car is still a slow bucket, just with a little more umph lol
    First things first I am a 2002 4g64 Turbo pushing 12lbs and with A/T. What I am trying to understand is my 02 galant ecu reflashable wiht an A/T? I have been hear for years and I havent heard anything positive about this subject. I dont want to go 5spd so thats out of the question. With the whole JET CHIP ECU thing i was wondering would it make alot of diffrence in preformance? According to them I can tell them to tune AFR,allow ecu to read and see boost pressure, ignition timming, and have ecu able to work with apexi safc2. To me these are the factors that matter the most when tunning so with that said have Jet base tune and me finer tune with safc? anyone?
    Also to Airborneparainf82- IS your galant flashed with A/T?
    you can flash your ecu, but it will only read up to 100% load. once you hit boost, the ecu will not know how much fuel to use, or even what is going on. Johnathansgalant was able to wire in a Evo ecu into his A/t. He has the evo ecu control his fuel and timing while the stock ecu is still controlling the tranny and other sensors.
    Quote Originally Posted by Boostdgalant View Post
    yes Im AT and flashed using ECUflash, but as qnz just stated, if your running boost then just a flashed ECU alone will not be sufficent to control what you need.
    Well JET says that when I reprogram/chip ecu that it will be able to see and function in boost...
    well then trust jet, and not members who actually know what their talking about. Go for it, let us know how it works out.
    00 Galant ES Turbo/5-Speed
    13 GTR
    4G64TT8G
    If jet said that they can fix it nd make it work then go 4 it nd give us details
    No.... It won't work. But go ahead and spend your money. I guess the 5000+ people with evos/subies/eclipse/galant are just idiots. lol
    jet charged a member from GF $450 to do his ecu and he said the car idles like sh*t when its cold but when it warms up its fine
    he is only running 5psi and thats all he wants, as far as him going over that i dont know how its possible since you need to use something to tune it
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    01-24-2005
    DFW/Stillwater
    2,752
    my car IS a jet!
    jet lag?
