Thread: GalantTuner10's build
Page 3 of 25 FirstFirst 123456713 ... LastLast
Showing results 41 to 60 of 490
  1. #41
    08-13-2008
    Waterbury, CT
    3,331
    Quote Originally Posted by ZigenScarface View Post
    it looks like the fmic is mounted vertically insted of horizontally
    yes exactly it is laid flat and flows very well in that position and no1 can c it at all
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  2. #42
    Who told you that?
  3. #43
    Proto
    That FMIC isn't going to get much air to it at all...
  4. #44
    08-13-2008
    Waterbury, CT
    3,331
    its not a matter of who told me that its a matter of ive done it before on a turbo tbird and it flows very well there.. it isnt something any of you have done so dont think you guys all know.. and if there is an issue i can change it later on.. im not worried about where it is at all
    2014 Lancer Evo GSR
  5. #45
    Lol yea that turbo is going to get hot as hell
    1996 galant s
  6. #46
    08-13-2008
    Waterbury, CT
    3,331
    Quote Originally Posted by Galant306m View Post
    turbo gets hot anyway its a matter of heatsoaking the intercooler and causing overheatinf of the system.. but it flows well there trust me
    2014 Lancer Evo GSR
  7. #47
    I think MItch meant the air flowing through the turbo will be hotter than usual.
    If you say it works by experience then I wont go against you. But I highly doubt its efficient in that spot.
    and I've tried it all, SMIC, FMIC, TMIC, etc. I've even played around with air-water intercoolers.
    are you going to make a duct that will direct air into the intercooler atleast??
    well, nonetheless good luck with the build hope it all works out for you
    Jigz-TGCIL Sosick Motorsports
  8. #48
    08-13-2008
    Waterbury, CT
    3,331
    if you look at the design of the bumper all the air comes in below the radiator and everything and is directed up.. theres a piece that helps push the air up.. i know it gets air and flow cuz driving in any wet conditions the top od the intercooler is covered and the only way water can get there is from underneath
    2014 Lancer Evo GSR
  9. #49
    or its coming in through the grill.
    Lol before my G1 cut my post off it read
    That turbo is going to get hot which having your FMIC mounted like that and not getting alot of air the intake temp is going to be outrageous.!
    1996 galant s
  10. #50
    Proto
    From owning a turbo eclipse and working on various other turbo cars... you are going to heat soak very bad..
  11. #51
    Quote Originally Posted by Proto View Post
    agreed. we're all just trying to help you bro.
    Try it like that, tune it and see how much power you make.
    on the same tune, mount it the right way and see how much power you make then.
    it will be a big difference and the intake temperatures wont be as high.
  12. #52
    I'd like to see the results with this IC setup, there are quite a few Rx7s running V mounted intercoolers that are almost laid flat, and they seem to do just fine, so we'll see
  13. #53
    i think it could do fine, i mean i like the idea but i think the way the 7g front is made not much air makes it to the top. I might make up a duct for you if you want just send me the dimensions of your FMIC and i will use my usdm bumper and make something for you to direct air to the fmic.
    1996 galant s
  14. #54
    ^I agree with you completely, as long as there is proper ducting, he should be fine
  15. #55
    i think i will cad something up tonight when i get off of work. should be easy to make
    1996 galant s
  16. #56
    We must also not forget about the temperature of the air after passing through the intercooler. While a complicated duct that somehow manages to not block the radiator (while still providing enough cool air to the intercooler to not make it completely useless) seems like a reasonable band-aid, the air will be flowing straight into the hood latch area and the hood, greatly decreasing the velocity. In a normal FMIC setup, the air flows straight through the intercooler to the radiator, and is then pulled through by the cooling fans into what is usually a reasonably open space in the engine compartment, instead of trying to cram all of the air into a tiny area by the hood latch. There's a reason that most factory radiators and intercoolers (the STI being an exception) are mounted perpendicular to the ground. I'm no mechanical engineer or expert in fluid dynamics, but it kinda just makes sense.
  17. #57
    08-13-2008
    Waterbury, CT
    3,331
    Quote Originally Posted by greddy View Post
    exactly i took this mounting idea from that style and this is how we did it on the tbird
    the air is coming from underneath not above and the 7g bumper gets plenty air in and it gets turned up toward the radiator and such.. there is no right way to mount an intercooler only the commonly accepted way
    2014 Lancer Evo GSR
  18. #58
    10-05-2008
    Grand Rapids Michigan
    1,141
    It all takes faith.......
  19. #59
    hey i hope youre right. with the bumper you have its hard to see anything thru it anyway. the location will also make the IC piping route longer and as far as i know many DSMers prefer a shorter route piping
  20. #60
    TGC Regular bmore303's Avatar
    03-11-2007
    Baltimore, MD
    773
    Get an IAT sensor and test both positions. Arguing the physics of this would be a waste of time and would go over most peoples head's.
    RIP
    1995 7G 4G64 / 63T DOHC Turbo
    Part Out Coming Soon
    In search of 2G 3000GT VR4
    Daily driving
    Dat '08 Cobalt Coupe
