a trans shop could probally weld it up.. check with a transmission shop..
is there made some kind of differential-lock/LSD or something for the 7G AWD? I don't know the name in english. I want to lock the shafts between my rear wheels, I want. Any ideas, other than velving?
Mods:
why would you want to do that? A Lancer Evo LSD will go in the rear no problems, just make sure you have the correct ratio (3.909).
No you can't use an Evo IV LSD as that's AYC. You need an Evo1-3 LSD with 3.909 ratio
won't the LSD itself in the EVO123 diff just slap onto the Galant AWD ring and pinion gear? Then you don't have to worry about gear ratios.
Cusco Kaaz and ATS are a few places you can go to to get your LSD. EVO123 chassis code is CD9A.
how about diffs for E39A galant VR4? will those fit?
Do the actual AWD 7g galant come with the same rear end as 2g Eclipse AWD or Mitsubishi had come up with some totally different. As far as i know Evo 1-3 share the same setup as 6g Galant VR4 and 1g Eclipse AWD /GSX/ and Ive never heard of someone swapping 1g differential to 2g car. I might be wrong tho, the actual gears might match
I have no idea actually. But funny thing is this, I just did my rear diff on my JDM 7G VR4 and the one that came from an Asian junkyard (another 7G VR4) and the one that was on my car uses completely different axle inserts.
On my car:
spline insert, the axle end comes out with a flathend screw driver. The shaft ends where the splines end.
on the junkyard car:
spline insert, the axle end comes out with a flathead screwdriver. The shaft end has a protrusion that's round and splineless that seem to go across the differential.
both diffs are 3.909:1 with Viscous LSD (on the label outside at least)
and a 1G diff is like 3-bolt or 4-bolt i.e. the axle shaft comes out when you undo 3 bolts/4bolts..... but I have yet to get my hands on one
According to Mitsubishi ASA the 7G VR4 rear diff is unique - it doesn't share a part number with ANY other car. the part number for the whole assembly is MB912578
2G diff is similarly structured isn't it? but the gear ratio floats around 3.4xx to 3.5xx
breakdown: D27A = 1G D33A = 2G E39A = 6G E84A = 7G CD9A = EVO1
the LSD unit part number
for D33A: MB569986
for E39A: MB569831 (open differential)
for E39A (JDM!): MB393864 (viscous type, with clutch versions available, same as CD9A one.)
for D27A: MB393864 (viscous type)
for E84A: NO DATA
for CD9A: MB837571 (Clutch Type LSD)
we know that E39A and D27A rear diffs are interchangeable...so assume that the LSD bolt pattern is the same.
ring and pinion set part number
for E84A: MB860149 at 3.909 shared with EVO123 and Expo
for D33A: MB185307 at 3.545
for E39A: MB185307 at 3.545
for D27A: MB185307 at 3.545
for CD9A: MB860149 at 3.909
so by deduction you can kind of see how the different diff slaps onto both 1G and 2G because the ring and pinion are the same kit. What's left is wether or not the splines are the same so that the 2G spline type will correctly "snap" into a 1G differential - which would be the same differential as a CD9A EVO123.
so there you have it. use this information to your own advantage.
Has anyone with an AWD weldedthese two shafts? I seriously thinking about welding it, but... I'm just nowquite sure what to do... I don't want to ruin anything on the car...
how can i get a AWD 7g stateside?
"One good thing about music, when it hits you, you feel no pain." - Bob Marley
you can't
lol... im sure you can, no one has tried hard enough yet. :)
come buy mine then.
we dont have emissions here in florida so it shouldn't be to hard. thanks again.
15 year old twin turbo machine that hasn't been raped comes in unicorn flavor.
