Its way to early for me. I'll let someone else explain this to you.
Well I bought a "V6" throttle body for my I4 today. Took it apart to clean it and was doing some measurements and it seems to be the same exact size as the TB in my car.... hmmm. What do you guys think? Did I get played a fool?
while you're at it, go buy a v6 instrument cluster for your i4 and make a review on it.
Never fucking mind
I was told that the v6 throttle body would not fit right on thr 4cyl....or would it?
you can tell just buy looking without a ruler ones bigger.
You sir, need to learn to read rulers
not to mention that both measurements were taken at different spots. you fail.
'Nuff said
Chip
(Paint Code: Porsche LC9Z)
Oh wow you guys are retarded. I love how you jump to conclusions and assume i'm retarded. Obviously as you can see from the first pic it tapers. For every one on the tgc board let me explain that to you. As the hole goes in.... It gets smaller.... Now with that being said did you guys take time to consider that is the same throttle body??? Those two pics are front and back dip shits. I never took off my i4 throttle body only did quick measurements from under hood fuck face. Wow, i wouldn't expect any less from you guys though. I was hoping to get some intelligent responses and i get this stupid shit. Thanks tgc!!! Later fuckers.
Are you guys sure these arent the same throttle body? 3rd pic is the back of the tb. I know the 7g tb is tapered, the inlet/intake side is 60mm, the outlet/intake manifold side is more like 53mm.
I think you all fail, this is the same tb! pwned!
sarcasm dude? what sarcasm you all were fucking making fun of me cause I showed you pics of the same throttle body, which is the same size in my I4 just never put any pics of the I4 one do I need to spoon feed you?? I posted pics of front and back to tell you guys I was gonna try to bore it out and get your opinions. Thanks but I'd much rather get ideas from people who can realize they're looking at the same piece of metal WITHOUT jumping to conclusions.
No need to call names. Everyone above was too quick make judgements.
I dont believe boring it out is a good solution at all. Does the v6 tb not bolt up to an i4 intake manifold? Im sure the i4 tb is not 61mm on the outlet side if its anything like the 7g sohc tb.
Noob starts insulting senior members and nothing happens, not even Off topic. Well I'll be damned if there's not some favoritism going around these boards.
You're going to bore out your TB? On your 4 banger?
HOLY FUCKING SHIT! You might get .5 whp out of it.
You are a dumbass. Do you have an older brother named TJ?
Well every one of you answered his questions wrong, and every one of you answered his question with a sarcastic type answer.
I searched, the v6 throttle body will bolt up and work fine. I didnt find the inlet/outlet sizes though. So someone else will have to confirm if those are the right measurements for a v6 tb.
