Thread: Fogs WOnt turn on
Showing results 1 to 12 of 12
    617Lowrider
    Fogs WOnt turn on
    i got 01 galant that ive tryed everything but i cant get them on ... its my 1st car so any advice on how to get em workin would be grat thnx
    do you see a green light on the left hand side on he gauge panel light up when you press it? also fogs will only come on with low beams. Check the fuse for fogs also, im not sure if its under the hood or the fuse box by the drivers door.
    00 Galant ES Turbo/5-Speed
    13 GTR
    02-28-2005
    Metropolis
    3,540
    Check the fuses first. If it/they are fine check to see if the bulbs are any good.
    did u push the button?
    It might be the relay, if the fuse isn't blown or it could be the fog light switch itself.
    Experienced TGC Member dwjp90's Avatar
    04-13-2008
    west chicago, il
    1,150
    turn your car on, put your low beams on and push the button, did it work?
    if no, (turn your car off) check your fuses (both the engine bay ones and the cabin ones) and see if it works this time
    if no get a buddy to listen next to the engine fuse box for a click, if there isnt a click you need a new relay (junk yard if you want to be cheap)
    617Lowrider
    Quote Originally Posted by dwjp90 View Post
    ok fuses are ok .....and theres a click and the icon shows up on the dash but still no right :( so it must be the which bulbs should i get to replace them?
    04-13-2008
    west chicago, il
    1,150
    look in our sticky about bulbs
    fogs are 893 bulb
    13 GTR
    617Lowrider
    Thanks
    617Lowrider
    i got them to work now but the bulb wont stay in
    01-19-2007
    Lyndhurst, NJ
    3,473
    Use less lube.. no but seriously.. they should just twist right in..
