Thread: Axles and TB
Showing results 1 to 18 of 18
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Axles and TB
    Hey guys just a quick question, Im almost done with the build and just thought about the axles and tranny. My goal is to hit 350 hp, but im a little worried about my tranny and axles. Will they be ok? Also as far as the TB goes, im not thinking on doing this b/c Im not sure if its nessasary to change the TB from the 4cyl to the 6cyl or if anybody would know that I should do this or not. If staying with the 4cyl TB will I still hit 350 hp?
    Thanx guys
    are you still automatic?
    12-02-2008
    1,263
    Yes
    transmission probably wont hold up at all if ur planning for 350hp
    12-02-2008
    1,263
    I was thinking of either getting engine rebuilt or later on getting a 5 speed swap just dont know what tranny to use from to put into my 2002 galant. What do you think would be best?
    5spd swap information is posted many times on this forum, just search (or check the tutorial section for the swap and you will find the info u need) just rememeber 02-03 cars require a speed sensor rewire and you will have have a CEL, all info is covered in that thread
    08-04-2003
    NY
    4,344
    worry about the tranny, the axles will be fine.
    99' Galant ES
    4G64/63T
    AEM EMS
    12-02-2008
    1,263
    Would anybody know if its posible that I can just rebuild the auto I have, or should I swap to 5 speed. I dont know much about trannys at all. I been surching all over and seen nothing. Would anybody know what year tranny from an eclipse would fit and would it have to be form a turbo eclipse or just a 5 speed?
    Please someone help:(
    rebuilding the auto is a waste of time, do the 5spd swap, u'll be a happier person in the end
    12-02-2008
    1,263
    Would you know what tranny I would have to get? I found 98,99 turbo tranny, or would I have to get just a 5 speed and from what year?
    TGC Regular Boosted's Avatar
    12-03-2008
    Fayetteville, NC
    575
    From a 3G Eclipse, 2000-2005. If you have a 4G64 (2.4), you need to get a 5-speed transmission from an Eclipse with the same motor.
    12-02-2008
    1,263
    Thank you very much. But I do have one questions does anybody know whats the difference between an automatic tranny and a 5-speed when it comes to putting more HP? Why cant the auto take the power but the 5-speed can?
    08-04-2003
    NY
    4,344
    because its built like shit from mitsu
    the trannies break on stock power over time. its just not made for that
    also, to make the 5 speed hold high HP over a long period, you will want to get a LSD. Look in the 8g performance section, there is a whole 5 speed swap thread, you cant miss it.
    99' Galant ES
    4G64/63T
    AEM EMS
    12-03-2008
    Fayetteville, NC
    575
    Read this:
    https://www.thegalantcenter.org/sear...earchid=314220
    The only transmissions made for power from Mitsubishi are those found in the Evolution and some VR-4 models.
    01-19-2007
    Lyndhurst, NJ
    3,473
    You have a lot to read up on before you make 350...
    04-10-2005
    NYC
    3,695
    as said for the tranny to be rebuilt it will be expensive, and while not neccisarily a waste of time for that hp the 5 spd will definately be more satisfying and responsive. the 5 spds are actually built fairly well the only weak point as stewi said is the differential. swapping to a lsd is proven to hold over time. it will also benefit in getting power to the wheels and for traction as well...obviously you would need a clutch upgrade as well for that hp
    for the tb if that is a concern, your better off getting hold of an outlander intake manifold and tb. not only is it better made but it is larger...if you decided to you could always do a pp job on it
    12-02-2008
    1,263
    Whats a pp job?
    Banned
    06-07-2008
    Orlando FLAWDA
    533
    port & polish
