Thread: picking up a turbonetics T3/T4
Showing results 1 to 14 of 14
    08-13-2008
    Waterbury, CT
    3,331
    im using it later on as an upgrade 4 the 14b im putting on soon... i was wondering if i were 2 do the 1g head swap and run 550cc inj on top of wut im already doing if anything else will need to be done so i dont blow anything up
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    a t3/t4 turbo uses a different manifold than a 14b. it wont be as simple as switching the turbo. you'll have to re-do your downpipe, among other stuff
    08-13-2008
    Waterbury, CT
    3,331
    ok i did realize the manifold and down pipe
    im getting it as a package deal with another turbo we r using on the rb25 were putting in the 240 so im getting it cheap.. the real question is can i get away with stock internals if i dont run crazy boost?
    2014 Lancer Evo GSR
    04-10-2005
    NYC
    3,695
    well if your considering a headswap...at that time it wouldnt be a bad idea if you want to run high numbers to install at least new pistons...the 4cyl can take a decent amount of boost especially on a good tune but there is still a limit obviously replacing even only the pistons will raise that
    the 16g is the normal upgrade for those running a 14b it is a bolt on i believe
    08-13-2008
    Waterbury, CT
    3,331
    true the 16g is a bolt on, but im getting this turbo in a package deal so im gonna have it so why not use it or ill sell it and get an 18g and do the headswap and run high numbers.. im thinking now cuz i have a 14b and this turbo.. which should i pick?
    2014 Lancer Evo GSR
    Member
    11-24-2006
    nor cal immigrant
    145
    what is the a/r on the t3? what kind of tune are you going to run.. and what is the compression in the motor..
    222whp/250wtq
    08-13-2008
    Waterbury, CT
    3,331
    its a 50 trim, its coming with an hks gt3040 as a package from a buddy and i only cared about the hks's specs.. id run a pretty in depth tune and compression is whatever it is stock( can't remember exact numbers)
    2014 Lancer Evo GSR
    Dohc head swap makes it worse cuz it raises the compression, and the 50 trim is a lil overkill for stock ECU unless youll be doing 2g ECU swap. 14b can handle all the power you can make on stock internals and stock ecu
    Member
    11-24-2006
    nor cal immigrant
    145
    you have to find out your compresion, and use a tubo map to layout where you fall. lmk if you dont understand what im talking about i'll explain it. but you need to get a map for that turbo, it's going to be a little bit of figuring out.. but you can probably push 10 psi on a 9.5:1cr depending on the tune. ive seen 15psi from a t3/t4 on a dd . with the compression of 9.5:1cr. but depending on your tune and the compression it will tell you where you can place it.
    easy read:version
    stick it on a dyno and just keep bumping it up the psi and tuning it as you go.
    08-04-2004
    Westchester NY
    1,332
    oh boy.. kaboom
    08-13-2008
    Waterbury, CT
    3,331
    haha no going boom
    i am doing the ecu swap if i get an eprom 1 for a good price and im just gonna sell the t3 t4 2 a buddy that has the cash 4 200 more than i got it for.. i think that going 2 an 18 or 20g in the future will be a better idea
    but thanks for the input
    2014 Lancer Evo GSR
    so is this a turbonetics turbo or a hks turbo?
    08-13-2008
    Waterbury, CT
    3,331
    its a turbonetics, got an hks 2 lol
    2014 Lancer Evo GSR
