Thread: Clicking under the hood, any advice? :)
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 45
    Hey guys!
    When I turn my car on there is a rhythmic clicking noise, the higher the RPM the faster the clicking, so it's obviously related.
    I've heard engines sound like this before, and mine started doing it, it makes it sound like a POS so I'd like to fix it :)
    Any advice on what to do?
    05-31-2005
    4,735
    leprechauns do that. they will eventually leave.
    but it might be you lifters.
    TGC Regular youngin3's Avatar
    04-02-2008
    Dallas, Texas
    642
    Check your oil.
    If you are a V6, are you using 93 at the pump?
    Quote Originally Posted by lavie2k9 View Post
    Check your oil.
    it's a 4 cylinder, I'm using regular unleaded.
    And someone else told me it's my lifters too. How would I fix that problem?
    its teh lifters, u can add rislone or some kind of oil additive to help it, or u can bleed them out
    04-02-2008
    Dallas, Texas
    642
    bleed them out?
    Rislone is what I wanna get?
    Remove them, soak them in carb cleaner overnight, then shoot carb cleaner through them to clear them, reinstall.
    oil change usually fixes the sound. i add this to the oil if the sound returns between oil changes:
    or
    the sound is caused by sticky lifters. they sitck because they are coated w/ varnish from old/dirty oil.
    or
    Yea I just had my oil changeda couple weeks ago. I'll try adding some of that stuff to it. Just pour a quart straight in where I put oil in?
    exactly.
    exactly.
    Cool thanks man. So that should stop the noise?
    04-02-2008
    Dallas, Texas
    642
    Would it be better to take off the head and clean all the lifters and valves out?
    if u got a weekend to waist then sure
    i know a guy that saw a guy that knew a guy that once passed by a car that had been painted. Ill ask him tomorrow after consulting my magic ball to determine WHERE YOU LIVE in proximity to a paint shop NEAR WHERE YOU LIVE..................
    10-24-2003
    1,432
    Get rid of the Fram oil filter if one is on your car.
    www.gooichimotorsports.com
    03-12-2007
    Dallas TEXAS
    2,041
    Quote Originally Posted by 6G72gearhead View Post
    whats wrong w/ fram oil filters?
    Whatever oil you use, just use Mitsubishi OE oil filters. I had used Mobil One in my 01 I4 ES and the lifter tick was almost non-existent afterwards. Then in my GTZ I used AMSoil filters and 5W30 oil.
    The filter element quality and flow characteristics. I don't think they match well with what our oil pumps send through the engine. Use Mitsubishi, Mobil, or AMSoil filters.
    10-24-2003
    1,432
    They have a crap anti drainback valve and end up on full bypass all the time and end up running low oil pressure at idle and end up starving the lifters for oil.
    Wix is about the best non OEM filter on the market, the Amsoil is a joke, they are usually re badged frams or puralators. The Mobil 1 is a nice filter but a bit overpriced as you can get the same Champion Labs filter under other names for alot cheaper.
    Wix is OE for a lot of manufacturers, after having disassembled 15 or so different brands of filters here at school I am pretty set in my decision to stay with Wix filters. Also V6 guys, you can run a 51334 filter instead of a 57062 as the 51334 is bigger, and used to be what Wix recommended for our application any way. The 51334 is what they still recommend for an '02 Isuzu Trooper, if you need an application to remember.
