p.s. if you forget the paper towel pieces tucked into the oil drain holes and drive for a few miles, don't panic. the paper towels will act as additional filters and at the same time won't harm your catalytic converter.
Galant Evolution, did you replace your head cover gasket? when i got back in there, the new gasket seemed to be leaking oil all around the cover, like almost 360 degrees. did i undertorque the six cover bolts? PDF manual says that the torque is 30 inch-lbs, which is a super tiny amount of torque.
