Battery isolator ftw..
im getting ready to run dual batteries in the galant due to the air ride compressors and the audio/video set up. i already have a high output alternator so my question is, should i run a battery isolator, or just wire up the bateries in series, and if i do wire them up in series, does any one have a diagram. thanks
------- spark it or park it-----------
do u know what amperage isolator ?
wait? ur gonna wire up 2 batteries in serial? are you crazy?
wire them up in parallel
LOL.. Series not serial.. And yes you would wire them up in parallel..
lol told you i failed that class
12 Volt 100 amp batteries
2 batteries in Series = 24volt 100 amp/hr
2 batteries in Parallel = 12 volt 200 amp/hr
does this help?
Need to be parallel as the diagram indicates. You want 12V, not 24V.
2003 Mitsubishi Galant ES
i wouldnt even get a regular batt,i have a kinetiks gell cell batt they have really high rating like one of there batts it the same as like 1000 caps.and the somewhat cheap.this is the site if ya wanna check them out http://www.kinetikaudio.com/default.asp.
http://www.cardomain.com/ride/3012568 CHECK IT OUT
my buddy built the alternator for me, its a 250 amp, 150 at idle
thanks for the help though
