Thread: Do I really have to swap the throttle body?
Showing results 1 to 20 of 23
    08-13-2008
    Waterbury, CT
    3,331
    im doing the ecu swap soon and i have most of what i need. now the big question is do i have to change 2 a 4g63t throttle body or is there some way to use my stock throttle body?
    i also planned on staying sohc and keeping the distributor 4 now will i run into any problems with this??
    any help or advice is much apreciated. thanks
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    you're stock throttle body will bolt right up to any of the 4g6x manifolds.
    I don't see any reason why you'd have to change it other than perhaps a different order to the coils within the IAC.... but that could easily be corrected by switching a couple wires(if its even neccesary)
    although i'd rather have a 60mm throttle from a 94 GS or a 1g 4g63
    08-13-2008
    Waterbury, CT
    3,331
    im asking because the repinning the ecu connectors tutorial says u need the throttle body and coils and stuff.. i was just wondering if i really need all that stuff and if i only need some of it.. cuz i have some of it like the injectors, resistor pack and stuff
    2014 Lancer Evo GSR
    when you setting this up hit me up...
    well the 7g sohc iac and the dohc iac's are actually different.
    however they work exactly the same. there are 4 coils. and depending on which coils are energized at the moment... it controls where the pintle is located, and thus controls how much air can bypass the throttle plate.
    if the coils are wired in a different order, then using the sohc iac w/ a dohc ecu... may cause idle issues.
    unless you can insure that the coils are wired up in the proper order.
    I don't even use an IAC. I bought a blockoff plate a long time ago and enjoy my perfect idle.
    08-13-2008
    Waterbury, CT
    3,331
    hmm ill probably swap 2 a 1g throttle body to make sure all the wires are correct.. thanks 4 thelp stunr
    xxl.. im starting this som etime after im done with the 240
    2014 Lancer Evo GSR
    thats just one of the cheapest mods to make little more power. and id reccomend the block off plate. I may need to physicaly hold the gas pedal for a couple of minutes, but its worth it.
    ok than
    08-13-2008
    Waterbury, CT
    3,331
    so i will go 2 the 1g trottle body and get the block off plate.. now the other issue is can i run everything else the same or do i have 2 modify for the diffterent ignition like coil packs and such
    edit: i found a GS throttle body near me and should that wire right up with the 2g ecu and ill still get the block off plate as well
    2014 Lancer Evo GSR
    08-13-2008
    Waterbury, CT
    3,331
    so im either getting a GS throttle body or the 1g nt 60mm one.. now for the block off plate the only one i can find is for the 1g.. will that also work on the GS throttle body?
    2014 Lancer Evo GSR
    All 1g Dohc throttle bodies have the same FIAV, so yes it will work
    yes.
    just not the sohc afaik
    11-14-2007
    Boothwyn,PA
    719
    Where could i find a block off plate at?
    08-13-2008
    Waterbury, CT
    3,331
    ok so i got a 1g throttle body.. now the only thing he kept from it was the tps and i was wondering if i could use my tps on this throttle body.. if not ill pick one up
    2014 Lancer Evo GSR
    look at TPS, if it has 4 pin you can use it with galants harness. if it has 3 pins then youll have to swap it
    08-13-2008
    Waterbury, CT
    3,331
    its a 3 pin tps on the 1g throttle body
    2014 Lancer Evo GSR
    not always, but yeah youll have to swap it
    08-13-2008
    Waterbury, CT
    3,331
    i cant find any 4 pin ones they r all 3
    2014 Lancer Evo GSR
    did you port the manifold yet
    08-13-2008
    Waterbury, CT
    3,331
    im gonna port the 2g mani when i get it
    2014 Lancer Evo GSR
