Thread: suspension setup
Showing results 1 to 2 of 2
    dlvetoblue
    suspension setup
    hey guys, currently, i have progress springs with front KYB AGX's and back tokico illumina's. I got the set up done at Road Race Enginneering and it turned out to be a great set up. One problem is that I don't like the amount of drop with the progress springs. Before, i use to have Ground controls (which use Eibach springs) and i had the front a little lower than the back. About an inch and a half wheel gap in the front and about 2 inch gap in the back. The front doesn't drop as much as I would like with the progress springs. I only chose to go with progress springs because Road RAce didn't want to take the risk in modifying the ground controls to fit my shocks & struts. I just need some knowledge from peeps who've modified their ground controls to fit the shocks and struts. I was also wondering if it affected being able to control the ride height at all after the modification. Thanks...
    easy way. try to contact ground control and see if they can sell u a sleeve for the kyb's...
    but yea i think the people modified the strut and not the coils...
