yes, these will work out of any 2g eclipse. The only thing that wont work is shifter cables out of 2g RS or GS. You need cables off GST or GSX
Will 2g eclipse clutch, brake pedal, and shifter assemsblies work in the 7g? I have been looking for 7g assemblies forever, but cant find any. Any help would be appreciated.
^^ it does work but you need to buy the tank which is separate for 2g and it is a part of the master cylinder for 7g
anytime you guys need the parts for the swap just holla at me cuz i got it all.
Drive It Like You Stole It!
7G Erubini Body Kit for sale
I have the master, slave, clutchkits, etc...... and if need i have a few trannies laying around too.
i have a tranny, clutch, flywheel, and starter.
I still need shifter and cables, slave, master, and clutch and brake pedals. If you have this and want to sell ....shoot me a total price. I have found all these on ebay, so if you can beat $200 i'll take it.
seth says the 2g gst/gsx shifter cables are just a tad bit short in the 7g setup, but will work with some bad langauge and elbow grease. slave cylinder is 2g compatible. clutch and brake pedals are 2g compatible. master cylinders are the same between 2g and 7g, there's just a difference in reservoir style.
i haven't been here for a while but i remember cutting corners on the master cylinder by buying used and in the end i ended up replacing it. i'd buy a new master cylinder and slave cylinder, but since you're getting them new just ask for the galant once to save the headache. they might be the same as the 2g but then you'll be sure the if it goes bad you can use the warranty since it was installed correctly on the right car. also you can reuse the axles from your auto to manual. i found that out when i took the broken cv joint and just took the shorter side to the salvage yards hehehe.
i miss my 7g:(
1990 GSX(91 eprom ecu set-up)
6-bolt jdm (GVR4)
16G turbo
3inch turbo back(flowmasters)
510cc
OSTRICH
FMIC
i told you guys the part numbers and what not for the master and the slave cylinders, why wont you pay attention lolol
well i know that but one can only wish for the best.
hey my auto tranny is goin and I need to buy a new 1....I wanna go 5spd so bronxbombr I need all u got...can u give me a pricing on the things I need...I dnt really know much so b easy on me
drop me a PM
