Thread: Lowering Kit
Showing results 1 to 2 of 2
    InfamousBeatz
    Lowering Kit
    I just purchased a 1999 Galant as my first car and was wondering what Lowering Kit i should use to drop it between 1.0 in. to 1.5 in. Would 18" rims fit on this or would I need a camber kit? Please write back your suggestions and opinions....I am a beginner to this.
    Thanks
    Re: Lowering Kit
    <div class='quotetop'>QUOTE(InfamousBeatz)</div><div class='quotemain'>I just purchased a 1999 Galant as my first car and was wondering what Lowering Kit i should use to drop it between 1.0 in. to 1.5 in. Would 18" rims fit on this or would I need a camber kit? Please write back your suggestions and opinions....I am a beginner to this.
    Thanks</div>
    if you want that drop go with the Eibach Prokit, i have that installed on my Galant and put 18's on it also, but if you want about 2 inches drop, go with progress.
