Thread: Alpine Speakers
Showing results 1 to 10 of 10
    04-01-2008
    Tempe, Arizona
    1,996
    Alpine Speakers
    I installed some alpine type s 6x9 in the rear deck of my 8g. I used the bracket that alpine supplied but every time i open and shut my trunk it rubs against the magnet of the speaker...did anyone else have this problem?
    no...i didnt use the bracket either. just install the speaker as is (without the brackets) and just make sure it's on good and tight. it shouldnt rub.
    04-01-2008
    Tempe, Arizona
    1,996
    Its nice and tight, I am going to rip everything about again this week to dynamat the speakers and I'll have to look then and see whats up. Ill try to use them without the brackets and see if that makes a difference. Thanks!
    yeah np. if you're just running on speakers i dont think you'd need to dynamat. but its always better to be safe than sorry. goodluck to you.
    09-25-2006
    Central, Cali
    1,145
    did u install them from underneat or above
    03 I4
    if the speaker is deep enough.. i can rub.. i forgot the actual distance from the metal frame to the bars
    04 Maxima SL in Bronze with Black leather
    03-12-2007
    Dallas TEXAS
    2,041
    make a spacer out of 1/2'' MDF
    04-01-2008
    Tempe, Arizona
    1,996
    [QUOTE]
    Quote Originally Posted by jimmy_o2 View Post
    I installed them from above.
    would I have to modify my back dash that covers the speakers?
    03-12-2007
    Dallas TEXAS
    2,041
    [QUOTE=showtime;455928]
    not for half an inch
    04-01-2008
    Tempe, Arizona
    1,996
    sweet, thank you.
