Thread: Fixing the Manual Swap Codes
Showing results 41 to 60 of 61
  1. #41
    evo and eclipse are the same....
  2. #42
    10-18-2007
    Glen Burnie, MD
    1,314
    so evo 8 and 03 eclipse m/t ecu are the same? If so then why hasnt everyone gone the cheap route and bought the eclipse ecu instead of the evo. Just tryin to get this figured out cause im an 03 and have a trans sitting in my garage, but want to wait till after emissions to swap cuz of the codes it throws.
  3. #43
    cause an evo ecu is alot easier to obtain then an eclipse one. and the processors aren't exactly the same yet close enough.
  4. #44
    10-18-2007
    Glen Burnie, MD
    1,314
    Ok well I got an 03 eclipse in the junkyard that I pulled the trans out of, would it be worth it to just get the ecu out of as well?
  5. #45
    10-18-2007
    Glen Burnie, MD
    1,314
    also, since you were saying it is almost identical to the evo 8 ecu. Would I be able to tune it the same way I would if it were the evo ecu because I plan on turboing the car later on after I do some much needed maintenance
  6. #46
    10-18-2007
    Glen Burnie, MD
    1,314
  7. #47
    08-15-2006
    Perth Amboy, NJ
    1,558
    bertune over at evom.net should be selling evo 8 ECUs at around $160 shipped; it's where i got mine. i haven't searched for eclipse ECU info yet. i'd figure pull out the eclipse ECU and give it a try. if that doesn't work, many over at evom.net are parting out cars and may sell an ECU here and there. Good luck.
    run1206's Rear Disc Tutorial
  8. #48
    Does it have to be a ecu from a 2000 eclipse, or could it work from any 3rd gen eclipse 2000-2005. I have a 2003 galant es and plan on buying a standard eclipse gs for the swap, so could I just use the ecu if its not a 2000?
  9. #49
    TGC Regular Boosted's Avatar
    12-03-2008
    Fayetteville, NC
    575
    You can use the ECU from a 3G, which consists from 2000 to 2005. Do you live in a county, city, or state with no inspections?
  10. #50
    04-02-2009
    Denver Colorado
    1,447
    GOOSEY...curious which resistor was giving you the problems? I see that 4 of the 5 codes were eliminated with the resistor "fix" but the 5th kept giving issues. Care to specifiy for us if it was the TC solenoid or one of the shift solenoids?
    www.blackheartmotors.net
  11. #51
    Can somebody clear up the process of how one does the evo8ECU swap? I wish we had a tutorial but from what ive read it seems as though all that is necessary to perform it is to buy the ecu itself, buy the conversion harness, remove the old one, and plug all the new stuff in?
    What else am I missing here??
  12. #52
    08-15-2006
    Perth Amboy, NJ
    1,558
    Quote Originally Posted by g-ride View Post
    It should be like that, but many times Boomslang screws up the pin locations on the harnesses. I have all the parts and even though I'm only using the direct harnesses (not using the auto ecu side since i'm manual now). I still have to get more wires. No-one wrote a full out tutorial but johnathansgalant did the conversion by hand and wrote the pin combinations, search for his threads; you'll see what pins go where in those threads (harness or not). Check Road Race Engineering and club3G for the diagrams comparing the Galant/Eclipse ECU pins and the EVO 8 ECU.
  13. #53
    okay, i guess ill order the boomslang and see what happens, is there a particular evo ecu i need? im manual so i guess ill need one from a manual evo correct, how do i differentiate them when i order?
  14. #54
    08-15-2006
    Perth Amboy, NJ
    1,558
    Call them and ask if they can make a custom harness: Direct Galant harness to Evo ECU (without the Y extension for the Galant Auto ECU).
    You would need a 2003 or 2004 ECU (both or EVO 8). Not sure how to differentiate but on those ECUs you can "delete" the codes with some modifications (can't remember the exact process how though).
  15. #55
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Just ask or tell them that your looking for an Evo 8 ECU. Make sure they understand that the ECU has to be from a Lancer Evolution a 2.0l Turbocharged motor. Cuz some people get confused, also all Evo 8 cars ECU have the same part number. Go to car-parts.com and you will find one for a good price, and all Evo 8 are m/t
  16. #56
    okay so i have put this off unfortunately and my emissions are coming up in a couple weeks and i need to fix this soon, i happened to come upon an ecu from a 2000 galant and figured id just hook this up to get pass the test.
    Can somebody tell me the process of how I can install this bad boy? plug and play? do i need a harness? do i have to go to a dealership?? somebody help haha
  17. #57
    10-18-2007
    Glen Burnie, MD
    1,314
    Contact SPD_FRK he has a conversion harness from a galant to evo ecu. Purchase that and the EVO ECU load the galant/eclipse rom and you will no longer have the trans codes.
  18. #58
    Id say its possible to disable the codes with EVo scan
  19. #59
    06-13-2008
    Bronx, NY
    2,606
    People chilll out I GOT THIS. LOL
    I'm going to have a lot of time playing with the dam 02-03 ECU since I’m going 5 speed and going to try to tune it somehow. I have the definition "xml" and rom for the 02-03 ROMS. I already see all the tables and injectors scaling and so on. I need to see if the ecu is flashable. Going to test write in to it. But I need a backup just in case it gets stupid. And yes if is flashable we could find the memory block and make a periphery to disable the codes. for people with 02-03 ecus the speedometer is not working and this is due that our harness dont come with the speed sensor, SO, Need to find out about that. i have a idea but i dont know if is going to work.
    SOHC Turbo
  20. #60
    08-15-2006
    Perth Amboy, NJ
    1,558
    02-03 Galant ECU is flashable, and johnathansgalant has the fix for the speedo.
