Thread: Evo Brembos clearing
Showing results 1 to 20 of 35
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Hey guys I kinda need to know this ASAP but would 18''x9 rims fit a 2002 G, also the off set is 30mm will that clear the evo brembos I have?
    12-02-2008
    1,263
    I found one thats 18''x7.5 offset of 45mm and other rims I found was 35mm will 35 mm be ok?
    03-12-2007
    Dallas TEXAS
    2,041
    sounds fine. just do a test fit
    Experienced TGC Member njjfudge's Avatar
    02-28-2005
    Jonesboro, GA
    1,447
    Hard to say without trying them out if the will clear the Brembos. The offset can be what your looking for but the rims may not have the backspacing needed, or the spoke design may be wrong. I have heard of someone running a 9" rim in the rear on an 8g before, but never saw it in person.
    9" on the front wont fit, 8.5" is fine but will rub on turns, 9" in the back needs very low offset and cut fenders lip, as far as clearing the brembos thats hard to tell
    if any of my info is wrong someone please correct me
    good luck
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    04-10-2005
    NYC
    3,695
    sounds like it will easily clear the brembos but are way wide for the car...they will stick out like a skateboard...unfortunately the brakes are quite hard to fit your best bet is to search around and see what other members are using who run those brakes both here and for the 3g...other then that try sticking close to the stock offset and size of the evo wheels...also they really cant have a lip at all with those brakes. if you go with the stock specs for the evo
    07-12-2007
    SoCal
    4,632
    I have 8.5" in the front and rear and mine dont rub. It depends on the offset, but I dont think 9" wide will fit in the front either.
    JDM Zenki Conversion
    12-02-2008
    1,263
    I just found rims 18''x7.3 with offset of 35mm just asking if that sounds about right? Clearing brembos
    12-02-2008
    1,263
    i ment 18''x7.5 correcting the one above
    Banned
    06-07-2008
    Orlando FLAWDA
    533
    I have 8.5" in the front and rear and mine dont rub. It depends on the offset.
    it also depends how low you are dropped. by the looks of your pics, ur not that low so probbaly thats the reason why you dont rub.
    If you drop your rear low enough, negative camber may cancell out the rubbing...but then you'll have another problem with the tires wearing out prematurelyand you dont want that.
    i'm 8.5 all around. At first was running with the negative camber but then my tires went to shit, so i had to buy a camber kit which corrected my tires consequently rubbing on the rear fender..so then..naturally i had to roll the rear fenders.
    12-02-2008
    1,263
    I found 7.5 so from that part I now it will fit but as far as the offset goes just woundering if 35mm will clear the evo brembos???
    12-02-2008
    1,263
    05-31-2005
    4,735
    by specs and not looking at the spokes, id say you have a 50/50 chance that it will fit.
    for reference, stock evo wheels are 17x8 38mm but their spokes are made to clear the brembo brakes.
    It all depends on the spoke design. Those look like they would fit, but you should do a test fit first. You may need the spacers and extended wheel studs.
    Love,
    Matt
    05-31-2005
    4,735
    our lugs is 5x114.5 not 5x112 fyi.
    12-02-2008
    1,263
    This is alot harder than I thoght
    12-02-2008
    1,263
    5-114.3 what if the lugs are this pattern
    01-19-2007
    Lyndhurst, NJ
    3,473
    I guess ur not buying my rims?
    12-02-2008
    1,263
    Well right now Im confused with rim sizes and I didnt want to say anything yet untill I find out what can clear the brembos I have. When I found out that your couldnt that when I kinda panict and was confused bout what what rims I can get. Thats why im here trying to figue out and see if anybody can tell me what rims size is ok and offset is fine. I hope this does not upset you in anyway and make us enamies is anyway, Im pretty much learning what can fit with the evo brembos. I thought I can just get 17 or 18'' rims and ill be ok. All of this is new to me please forgive me Jeffy
    01-19-2007
    Lyndhurst, NJ
    3,473
    It's all good... All you need are spacers, and they will clear..
