Thread: OBX Turbos
Page 1 of 4 1234 LastLast
Showing results 1 to 20 of 65
    OBX Turbos
    Have anyone here ever buy a OBX turbo or have any cons or pros about them.Because i was thinking about getting this one http://www.obxracingsports.com/products.php?pk=1041
    07-20-2003
    Orlando, FL
    3,169
    Personally...OBX doesn't strike to be a reputable name in turbos and wouldn't even consider them.
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Deff do not use OBX turbos, its the same as using ebay JDM turbos that you get with the cheap turbo kits. The only thing that I have used that put a smile on my face from OBX is the racing headers that I got from them. My car felt so much better and souded like a best after putting headers and full custum exhaust on my car. But do not use OBX turbos!!!!!!
    i got their turbo manifold. no problems here. but just stick to the type of turbos that are known of their quality.
    Fully Built 4G63
    HKS 272
    ported Dual Ball Bearing FP RED 84mm 25psi w/ external dump
    12-02-2008
    1,263
    Yeah they are fine when it somes down to making turbo manifolds and racing headers, very nice design and strong, but turbo wise I would go for at least turbonetics they have a pretty nice selection of turbos for a good price.
    12-02-2008
    1,263
    By the way whokilledhoughes thats a nive pic of your car man, nice job on it
    12-17-2002
    Sherman Oaks, California
    4,304
    OBX is like the pep boys brand of aftermarket auto parts, nothing but crap. you should only trust their non-moving parts, like braces and manifolds, and even then, i wouldn't put one on my car
    http://socallifestyle.com/
    1994 Galant GS 5spd
    I have OBX headers from them, but only for a while... First the gasket fired away between engine and headers, then between pipe with O2 senzor and cat..
    Finaly the one pipe crashes... No more OBX...
    www.mitsubishiklub.cz
    Dream, as if you live for ever, live as if you will die today, the choice is yours.
    12-02-2008
    1,263
    Damn man not sure if you job was done right b/c mine headers are still fine and I rip my car here and there.
    Now Im year and half runing JVT headers from Ebay and they are fine....
    they also make a Quaife like LSD im taking that, thats no good either then?
    1996 galant s
    honda guys swear by the OBX lsd.
    unfortunately as a testimant of their shaky quality....
    they mass produced a lsd for dsm's.....
    but once they started selling....
    everyone who bought one for thiwer ride found out the hard way..... that it wouldn't even fit. this is even with Shep being willing to do whatever modification it took to make it work... even he couldn't get it to work.
    Epic Fail.
    Turbo's aren't jsut moving parts.... they are plumbed into yoru oil system.
    If the bearing material used in the OBX turbo is sub par... it could result in that material polluting your oil system... and even causing aweful things to happen like lockign up your oil pump, or premature main/rod bearing wear.
    I'd jsut stick with a nice run of the mill high output Mitsu turbo. Dime a dozen..... and proven to perform
    yea ive been looking into better turbo's and obx was never on my list, a turbo isnt something i would want to go cheap on because it will cost you more in the long run if they keep blowing up or because of poor quality they cause engine problems.
    I think im just going to spend the extra money and get a quaife then worth the better quality and the lifetime warranty.
    1996 galant s
    ok thanks you guys maybe i will just get the eclipse down pipe they have. And how much power could you push out of a shock 4g64 sohc with turbo (t3/t4) setup.
    depends on the tune, and how well you put it together.
    1996 galant s
    08-13-2008
    Waterbury, CT
    3,331
    dont go t3/t4.. its a different mani and stuff just get a mitsu turbo and mani and shit like that.. dont make this harder than it already is
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    12-17-2002
    4,304
    Quote Originally Posted by Galant306m View Post
    i would stay about as far away from that as a chick who's barfing up ebola.
    Quote Originally Posted by XXL4G64 View Post
    if you have to ask, you shouldn't be asking.
    1994 Galant GS 5spd
    12-02-2008
    1,263
    Do you mean stock 4g64? If so people are running on 12-15...crazy basterds, but safly you could run 8 psi, untill you car gives up. I would think on putting stronger internals b4 doing this set up, theirs no point on turbocharging a car if your ganna spend all that money on tubo kit and tuning when not getting nothing out of it. If you ganna tubo a car be willing to spend b4 doing.
    12-02-2008
    1,263
    I love how on the web site the logo it (OBX R Racing Sport.....Shit is Good !!!)lol wow
    12-17-2002
    4,304
    uh.....no. no. 8psi on a 4g64 will have you wiping the road with pretty much anything else out there minus cars with price tags $100K+. guys have been running 8psi on their stock 4g64 for years and years without a glitch, education goes a long way.......
    1994 Galant GS 5spd
