Thread: Are evo8 cams the same as eclipse
Showing results 1 to 11 of 11
    i know that the evo8 cams are lighter but can they be use in a 2g head?
    yea they will work but u have to move the dowel pins!!
    O really what way thou i might try them and see what type of number i can get out of them and are these for aftermarket as well.
    www.team-2g.com.
    We were having this discussion not long ago.
    What part of the form it was in.
    TGC Regular bmore303's Avatar
    03-11-2007
    Baltimore, MD
    773
    It is possible but will require work like said.
    As far as lift and duration go in the evo 8 cams,
    Code:
    4G63 ( Eclipse/Talon Turbo Camshafts)
    Adv. / Dur. Dur. @ .050 Lift (in) Lift (mm)
    248°/248° 200°/200° .349"/.350" 8.86/8.89
    4g63 ( Evolution VIII )
    Adv. Dur. Dur @ .050 Lift (in) Lift (mm)
    248°/248° 200°/200° .386"/.367" 9.80/9.32
    And well...it's hollow so less rotational mass of course. In short it is beneficial on one end IF you have your setup built to match that lift better than a stock 2g....
    (lulz T25) Or at the same time it could be a headache and spending $300 on a set of DSM performance cams could yield a MUCH better result for your setup. Up to you.
    RIP
    1995 7G 4G64 / 63T DOHC Turbo
    Part Out Coming Soon
    In search of 2G 3000GT VR4
    Daily driving
    Dat '08 Cobalt Coupe
    i would try it but i just dont want to break noting. plus i know that we wouldn't have the mivec
    Quote Originally Posted by bmore303 View Post
    Code:
    This statement is so false!! Evo 8 cams will work with the dowel pins moved around and using a degreeing wheel to put the car at TDC. Its that simple!! My buddy Stephen has some Evo cams in his 2g making over 1000hp on turbo alone..
    03-11-2007
    Baltimore, MD
    773
    That's cool and all, but which part of my statement is false? Not starting a pissing match but cams alone isn't making that car.
    RIP
    Daily driving
    Sorry, i was talking about the last sentence Bmore wrote. Simple,if you find some Evo performance cams very cheap buy them asap. There are all kinds or tutorials on the net that will show u how to get these cams working..
    ok that cheap and fast part sound good to me LOL. and i bet with a 14b evo cams would pull 2x better on take off and boost better.
