Being that the camber plates are aluminum they may be subject to corrosion, I'd suggest making a rubber or metal cover of some sort to protect the camber plates when being used as a daily driver (at least in winter). Other than that anti-seize should be more than adequate for the bolts on the strut and the camber plate.
