Thread: How-To: DRL Disable
Showing results 1 to 20 of 26
    How-To: DRL Disable
    ill add more pics when i can....krazienluv10
    Here is a quick tutorial on how to disable your day time running lights
    Pretty much a 3 step process
    1) open the fuse box under the hood
    2) pop off the red box inside the fuse box (i believe new models have a black box or yellow)
    3) bend the pin slightly, make sure you u bend the right one... " pic is over exaggerated fyi "
    **** Make sure u bend the right pin!!!!
    uhhhh...... Whats a 9g???
    NEWBIE
    09-16-2009
    Hollywood, Florida
    36
    will that work to disable the DRL's on all models or do you think it will be different for the 4 cylinder models?
    Should be the same for 4s and 6s.
    Works like a charm took me 3 minutes hardest part was unlocking the car to pop the hood if that says anything about the ease of this job
    NEWBIE
    09-16-2009
    Hollywood, Florida
    36
    did it last night, a whole whopping 3mins
    05-01-2008
    Manitoba
    1,589
    if that doesn't work with other models you can just buy a anti flicker/canceller.
    Tuned 2013 Evolution X GSR PB
    What is the point in doing this?
    Do hyou mean the tiny bulbs in the headlight?
    that deffinetly took like 3mins to do sweet now my hid bulbs wont burn out as fast cool deal thanks alot bro.
    05-31-2005
    4,735
    did this today although i really use my headlights all the time. took like 30 mins.
    whats DRL ?
    4,455
    Quote Originally Posted by Fresh_617 View Post
    whats DRL ?
    daytime running lights
    Jason - - cofounder of TGCNY
    2001 Galant ES
    1 minute! top that lol. THANKS MAN!
    worked like a charm on my 4 cyl! so thats fact for 4 and 6cyls.
    please update the pictures we can see the steps ????????
    Icon2
    How did you bend it? I just did this 2 minutes ago, and mine are still on. I bent it both ways, but, if I bend the pin towards the middle (inside), it won't close all the way, so I know that wont work, so I just bent it towards the outside and it closed and all that, so I don't know what I did wrong. Seriously though, how could I have done this wrong lol?
    TGC Regular bgood12's Avatar
    07-17-2009
    554
    Why don't you guys like having drl's?
    Quote Originally Posted by bgood12 View Post
    I run HIDs and do not want htem on all the time.
    07-17-2009
    554
    Ok that does make sense then just wondered I did hid conversion on my 8 g but obviously nor drls. It is a conundrum cause I wouldn't want my hid always on but they use less power than the regular headlights, but replacing a ballast or some overheated wiring might happen so I understand it. Look into led for the rest of your lights I think as of now only my turn signals are still regular lights all interior/exterior are leds
