Thread: whats better for stock setup replacement kyb gr2 or monroe sensa-trac struts
Showing results 1 to 13 of 13
    whats better for stock setup replacement kyb gr2 or monroe sensa-trac struts.i need to replace taking off my tiens putting on gtz springs.looking to go to normal ride.
    11-13-2007
    -OKC-
    3,970
    KYB GR2 or KYB AGX
    kyb gr2
    TGC Regular Boosted's Avatar
    12-03-2008
    Fayetteville, NC
    575
    KYB AGX for sure.
    no between kyb gr2 or monroe sensa-trac which one im on a budget.going back to stock speings.im putting gtz springs on es v6.just want stock .
    11-13-2007
    -OKC-
    3,970
    kyb GR2 for sure.
    12-03-2008
    Fayetteville, NC
    575
    Go for the KYB GR2 then.
    also i put camber kit on when lowered car was there a stock camber kit on car factory?should i take off camber kit i had on w/lowering springs or keep on when i put the stock springs back on ?
    11-13-2007
    -OKC-
    3,970
    The alignment will be off once you change that angle. I wouldn't take them off but get another alignment after.
    i think it was only one either rear or front whichever was cheaper at the time.so leave the camber kit on.did the car come stock with camber kit?does it matter that the camber kit was for use with lowering springs or it will work with any.i will only benefit from it?
    like what everyone said..KYBs
    Quote Originally Posted by 01nygalant View Post
    You don't need any camber kit with GTZ springs, just get an alignment.
    monroe is crap.
    go kyb.
    Cali: Sig 3/28/2011
