Thread: is the fuel filter in gas tank or no on 03 galant?
Showing results 1 to 8 of 8
    is the fuel filter in gas tank or no on 03 galant? i want to change it.
    11-13-2007
    -OKC-
    3,970
    Yes, it's in the gas tank.
    ok thanks ill pass on it then.
    09-10-2003
    Charlotte, NC
    4,463
    Would that link basically be the way to install a walbro pump?
    01-19-2007
    Lyndhurst, NJ
    3,473
    How expensive is that filter? Part number?
    11-05-2003
    San Francisco Bay Area
    1,517
    Quote Originally Posted by Serstylz2 View Post
    Close, but here are some more detailed instructions:
    http://www.club3g.com/forum/performa...fuel-pump.html
    There are supposed to be pics - try asking Tearstone if he can rehost them.
    yes. but its so messy from the gas sloshing around and you having to put your hand into the tank, i rather not do it again. Best to do it when youre at less than a 1/4 tank
