Thread: Clutches?
Showing results 1 to 7 of 7
    Clutches?
    Im thinking about replacing my clutch in my 94 s when i change out the motor with the 50000 miler in my 97 and just wanted info on a cheap, strong clutch kit. Im looking for 20% more gripping power and above, but dont want to spend over 200. Any recomendations?? Thanks.
    I had the Exedy OEM replacement in my turbo Galant, held up fine, only have maybe 15k on it but its still running strong. $89 for the disc and pressure plate.
    You could get a Fidanza 2.1 for $250ish, same with a Spec Stage 1. Next up is an ACT 2100 @ $350ish.
    Clutch kit prices must have went up, I dont remember paying over $450 for my old 2600 way back when.
    This is a great deal on an Exedy clutch kit and Fidanza lightweight flywheel:
    http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
    ^That is the same combo I have in my Galant now. I have had this clutch since February 2006
    12-17-2002
    Sherman Oaks, California
    4,304
    i have 60K+ miles on my ACT2100 clutch. still almost like the day i put it in.......
    like said seth, the exedy has tons of great reviews, great clutch it is
    http://socallifestyle.com/
    1994 Galant GS 5spd
    Member RacerX4g64S's Avatar
    03-13-2008
    Outside of Philly PA
    139
    I heard good things about Exedy does anyone know the difference in between the Performance vs the OEM clutches? I once read that the only difference is a heavier pressure plate.
    Quote Originally Posted by RacerX4g64S View Post
    There's more to it involving disc design and material. Take a look at http://www.advancedclutch.com/ or http://www.exedyusa.com/race/.
    Bronx NYC (reppin)
    3,489
    i got them if you need it......
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    oem/street/ light race clutch kits all use the same disc.
    because a oem-like sprung hub disc is going to have the smoothest engagement, and least amount of chatter.
    so to increase the load capacity, they include a higher spring rated pressure plate. The increase in clamping force allows you to hold more torque.
