Thread: Nothing big
Showing results 1 to 14 of 14
    01-08-2008
    Levittown NY
    2,786
    Nothing big
    Has anyone ever made it so a light follows the track through the gears and individually lights tem instead of just lighting the whole set? I was looking at our shifter and it might be pretty easy to do just need something to hold the plastic piece that says them in and extend the little red reflector tab to contain a light and be boxed in
    Finished it
    https://www.thegalantcenter.org/show...169#post471169
    u mean like drill a hole through that red dot a shove an led in that hole?
    That's a neat idea. I might check into it when I've got my console out this weekend.
    2000 Mitsubishi Galant (totalled by semi, RIP)
    2000 Mitsubishi Galant - Bought off Craigslist, received organ donation from last one:
    - Engine/5spd trans/interior/suspension/brakes/etc. all moved from old car
    - 5spd | Outlander IM | StopTech BBK | Defi VSD-X HUD
    01-19-2007
    Lyndhurst, NJ
    3,473
    No, that's already been done.. Like on my car..
    What he's talking about is the actual letter lighting up.. instead of all of them at once when you put your parking lights on..
    Quote Originally Posted by Jeffylou87 View Post
    care to show us? and maybe some info on how you did it?
    - If you've got nothing nice to say, what the hell is wrong with you!?!
    01-19-2007
    Lyndhurst, NJ
    3,473
    Really old pic..
    01-19-2007
    Lyndhurst, NJ
    3,473
    Ill put together a tut in a few minutes.. Leme go take some pictures..
    01-08-2008
    Levittown NY
    2,786
    I just took pics of it dis assembled with my phone let me see if i can upload them to show u my idea and also jeffy's idea will be a good help
    edit: my phone is old and sucks cant hook it to comp and camera is MIA so you'll see what Im talking about when Jeffy posts his pics
    underneath the P-L is a black triangle shape that you put your light into and next to that is a tab with red reflective tape that shows on the circles next to the letters.
    My idea is to cut off the tab and use the bulbs stock mounting box and cut it with a razor then turn it sideways and attatch it to the track where the tab was.
    Extend the sides down to block the light from going to other Letters and it should light up the P and the circle next to it individually.
    TGC Regular youngin3's Avatar
    04-02-2008
    Dallas, Texas
    642
    I think he meant the actual letter lighting up, not the dot beside it.
    01-08-2008
    Levittown NY
    2,786
    Quote Originally Posted by lavie2k9 View Post
    I meant both its pretty easy once you have one done. Light shines through the plastic pretty easy and if you want it to be brighter just scrape the white layer away with a razor you can see the shape through the layer so its easy to follow the pattern.
    01-08-2008
    Levittown NY
    2,786
    ive finished the first prototype of mine it can be modified but it is still much different if anyone has picture texts that they can upload to the computer pm me and ill send u the 3 pics i have from my phone
    01-08-2008
    Levittown NY
    2,786
    For all those that wanted to see my idea in action
    lol damn cheap .3 mega pixel cameras
    as you can see with the original design that i worked on a total of like 40 mins shines into the other letters and wholes a little bit, I may change that i may not. If its good enough for you and you want to know how to make it ask me and ill make a tut if you're not interested then I may refine my idea then make a tut
