Thread: 2.4 dohc timing system
Showing results 1 to 11 of 11
    I would like to know can i use 2g lower time belt cover with the dohc 2.4 setup. oil pump as well
    08-13-2008
    Waterbury, CT
    3,331
    not sure about the cover but i know you dont have to change the oil pump use the same one you have.. the only timing components you need from the 4g64 DOHC are the cam gears and the timing belt oh and the spark plugs have to be for the 4g64 dohc
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    also make sure the cams are grounded to 2.4 specs rather than 2.0 specs
    because the spockets are in different places.
    oooo ok thanks
    you can use the 63 cam gears. you just need to advance both of them 1/2 tooth.
    08-04-2003
    NY
    4,344
    Quote Originally Posted by XXL4G64 View Post
    I would venture to speculate that it will fit, just like mine on the EVO/DOHC swap. The lower EVO cover fits the 4G64 block, but I have about 1/4" gap between the middle and upper covers. I also have a small gap around the bracket for the power steering pump, I dont know how the brackets look on the 7g blocks, so im not sure.
    99' Galant ES
    4G64/63T
    AEM EMS
    Quote Originally Posted by kolio View Post
    Could i buy two Galant 4G64 Cam Gears for the SOHC
    11-14-2007
    Boothwyn,PA
    719
    I dont belive so i think they are different sizes
    you realize that the cam gears are made for the timing belt. a SOHC belt has less teeth than a DOHC belt.
    stop tring to cut corners
    11-14-2007
    Boothwyn,PA
    719
    Kool aha i just amde an educated guess. thanks for backing that up kolio!!!!!
    TGC Regular bmore303's Avatar
    03-11-2007
    Baltimore, MD
    773
    Cutting corners? 2 New DOHC cam gears is less than $50. I'm sorry, but such a question just shows this project is beyond you and is almost irritating to read now.
    RIP
    1995 7G 4G64 / 63T DOHC Turbo
    Part Out Coming Soon
    In search of 2G 3000GT VR4
    Daily driving
    Dat '08 Cobalt Coupe
