Thread: How To:6G72 5 Speed Swap
Page 3 of 10 FirstFirst 1234567 ... LastLast
Showing results 41 to 60 of 194
  1. #41
    11-05-2003
    San Francisco Bay Area
    1,517
    Which axle? The passenger side axle on the V6 has a bracket that bolts to the engine block - there are two bolts if I remember correctly, then you can pry the bracket away from the engine as it sits on a metal dowel (or 2).
    To get the axle out of the tranny (presuming you have removed the hub assembly), just use a prybar to pop it out. *Do not* pull on the axle as you could damage the joints.
    EDIT: Reading comprehension owns me
    To get the axle out of the hub, I just unbolted the lower control arm, and pulled it down so the hub assembly can move around. Use a mallet to gently tap the axle out of the hub. Turning the wheels to the side you are pulling out also helps.
  2. #42
    ^^^exactly what I did, I'm going to steal that diagram you just posted and put it on the first post. Sorry guys I haven't been taking as many pics as I wanted. I'm going to start taking some more to clear some confusion.
    5-speed 6G72 w/ bolt-ons [sold]
    '93 Nissan 240sx vert
  3. #43
    ^^ I just removed the knuckles with everything attached, makes more room to work around, and its also easier than removing the axle nut.
    EDIT: Just finished pulling the fucker out of the car, it wasn't that hard
    '00 Patriot Red GTZ --> JDM'ed... 5 Speed... ...
  4. #44
    01-19-2007
    Lyndhurst, NJ
    3,473
    This looks easier and easier with each post that you guys make..
  5. #45
    Bronx NYC (reppin)
    3,489
    nice
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  6. #46
    Quote Originally Posted by Jeffylou87 View Post
    The hardest part of all is removing/installing shifter wires, its a pain in the ass to replace it, it took me about 3 hours just for that. Everything else is easier to do if you have the right tools.
    Also, I uploaded some pictures, including the cruise control wiring, check my previous post regarding it here: Cruise Control: how to make it work in your 8G after your tranny swap
  7. #47
    11-05-2003
    1,517
    Taking the auto tranny out is pretty easy - the hardest part for me was trying to install the manual tranny from underneath - I could not for the life of me get it to go in from underneath as the tranny would hit the subframe. It was much easier to pull out the engine and install the engine+tranny together.
  8. #48
    ^^^Crap, see thats what is worrying me is getting the 5 speed in.
    Yeah HondaKiller, getting the shifter lines through is the biggest pain in the ASS.
    EDIT: thanks for the hyperlink to wiring cruise control, will update first post this afternoon, i gotta go to school now. Haha i love virginia, we get 6 inches of snow and have been out of school for 3 days and today is a 2 hour delay ha!
    Double EDIT:
    On the contrary of living in VA, my clutch still hasn't arrived because of the snow, URG
  9. #49
    Mmmm so far so good....wow it feels like I did mine so long ago....
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  10. #50
    About the v6 passenger side drive axle: I read somewhere that somebody modified the auto tranny inner shaft and installed it on the manual. Is this true? If its true, how the hell I do it? I ordered the inner shaft from the dealer but its in back order until who knows when. Its the only part I don't have to finish the car.
    SOMEBODY PLEASE HELP ME!!!!
  11. #51
    04-10-2005
    NYC
    3,695
    the problem with the auto axle is its too short hence why you need to get the 3g manual one...im sure it can be modified however i would personally (and have for that matter) just get the 3g one so you are indefinately sure it works
  12. #52
    11-05-2003
    1,517
    Good luck with getting the shaft from the dealership (pun not intended ).
    Check your local junkyards. The one from the Dodge Stratus R/T manual fits too.
  13. #53
    Ok, I'm back from installing the tranny (was a pain in the ass), then tested the inner shaft, the auto tranny one actually is like 2mm longer than the manual one; and the splines are different (it slips) (THIS IS FALSE, I DOUBLE CHECKED), so I have no luck with it.
    BTW, congrats to myself, I'm officially 5 speed!!
    Quote Originally Posted by DryBear View Post
    ^^^ I checked every single junkyard locally, I found nothing!! I ordered the transmission from a place in Florida, then got it shipped here. I will call there on Monday, test my luck and see if they have the axle available. Otherwise, I will have to wait for the dealer. :(
    EDIT: The auto tranny inner shaft splines are the same as the manual tranny, and its still like 2.5mm longer. Just to clarify that ;)
    Also, I still haven't found the inner shaft, if somebody could help me find one, I will be happily thankful!!
  14. #54
    ^^^Congrats man!
    **Updated**
    Yep, another freaking weekend where i cant do anything. Me and my dad were supposed to drop the auto today and hopefully attempt to get the 5 speed in BUT, as said in another thread, my dad just laid off half of the employees under him and is now working his ass off.
    I'm considering at this point just to attempt dropping the auto with a friend instead of waiting, im getting impatient.
    Oh and pics were added here and there in the thread so it makes more sense.
    edit: Oh and Jeffylou, i did add the pics of master install, let me know if that helped or you want more.
    And 4g63lover, i added pics of the hub removal
  15. #55
    this may be a retarded question, and may have been answered before, but why is the pass. side axle replaced with the tranny being on the drivers? seems odd, i know there is a probable explanation that i can't think of.
    Member since October '03
  16. #56
    Its because of the way the manual transmission is set up, in this case its differential sits a little off compared to the automatic and therefore the automatic's passenger side intermediate shaft on the driveaxle is i believe longer (might be shorter) then what the manual tranny is set up for.
    Technically all you need is that intermediate shaft (passenger side) but you might as well grab the whole thing.
    Same thing goes for the starter plate, its just a quirky and tiny little difference. (refer to the original post for a pic of the difference between auto and manual starter plate)
    Hmm maybe later ill take a pic of the difference between manual and auto intermediate shaft...
  17. #57
    01-19-2007
    Lyndhurst, NJ
    3,473
    Would you be able to get pictures of the cylinder from the engine bay?
  18. #58
    quoted from goosey: "2001: REQUIRES A 2000 AUTO ECU/IMMOBILIZER WHICH YOU NEED TO GET REINITIALIZED AT THE DEALER IN ORDER TO GET RID OF THE CHECK ENGINE LIGHT"
    is this still true whether its for the V6 or not? does it affect driving habits?
    Steve
  19. #59
    04-10-2005
    NYC
    3,695
    it is true for the v6 as well
    it doesnt effect driving at all but you will either have to get an immobilizer that is flashed so you dont need to have it probrammed, or, you will have to take it to the dealer so they can rogram it to your key
  20. #60
    11-05-2003
    1,517
    What exactly do you want to see?
