Thread: How To:6G72 5 Speed Swap
Page 7 of 10 FirstFirst ... 345678910 LastLast
Showing results 121 to 140 of 194
  1. #121
    05-03-2007
    Socal/Central Coast
    3,803
    The wiring is pretty easy. Look at the pinout diagram, pins 7, 8, 9, and 10 are on the bottom. So go to the harness and you will instantly be able to tell which one is 7, 8, 9, and 10 by the number of wires in that row. Now, 9 and 10 is black/yellow and red/yellow. Splice and connect and TADA! The ECU thinks it's in Neutral. I actually ended up cutting and crimping connectors onto mine because I couldnt get any good connectivity with the splice connectors.
    okay at least you gave me wire colors LOL. because what I'm saying is that the circuit diagram can be interpreted in two ways: the plug shown is the ECU side of the plug, or transmission side. Whatever one its for, the pins are going to be on the opposite side for the other plug. And since I'm dealing with the ECU side, I need to know which one is shown in the diagram so I can know to reverse it or not
    and actually I just checked and I don't even have a red/yellow
  2. #122
    ah dammit. I meant to put red/black. WTF Jigz! lol.
    Jigz-TGCIL Sosick Motorsports
  3. #123
    05-03-2007
    Socal/Central Coast
    3,803
    okay this is how I first had it set up:
    the two thick wires were 9 and 10 and were shorted together (makes sense right? cause the it goes to the starter?)
    black with red and black with yellow were shorted together
    black with white and red with grey were wired to the speedo sensor
    this is how I have it set up now
    two thin wires were shorted and the thick wires went to the speedo sensor
    I'll check on colors in just a moment
  4. #124
    09-30-2002
    San Gabriel, CA
    573
    this just occured to me. in order to use cruise control again i just need to splice in a switch between neutral and D to pin 10... anyone tried it? will it cause any problems? and anyone know which pin is D off the top of their head? i'll have to look it up later tonight. another minor project for me to look into lol
    Your signature is too long.
  5. #125
    You got it the first time. 7 and 8 goes to reverse gear solenoid for the reverse lights, not the speedo sensor. 9 and 10 is shorted out to think the car is in Neutral.
  6. #126
    05-03-2007
    Socal/Central Coast
    3,803
    here's the circuit diagram
  7. #127
    05-03-2007
    Socal/Central Coast
    3,803
    err yea oops that's what I meant. We all make mistakes.. cough cough
  8. #128
    lol. yeah.
  9. #129
    just kinda curious if you saved your cruise control? would be interesting if you did, any info woud be great!!
  10. #130
    i have the i4 i wont to swap what parts do i need can you guys write out a list and send it to me
  11. #131
    TGC Regular stvn_mj's Avatar
    07-30-2008
    Avondale, Arizona
    961
    ^Sure I will make a list in the search button at the top of the page.
  12. #132
    05-03-2007
    Socal/Central Coast
    3,803
  13. #133
    Do I need to get a new ECU to complete this Automatic To 5-speed swap? I'm confused at the part where you short out the pins on the black harness to trick the ECU to thinking your in neutral. Basically does this mean you guys are keeping the stock ECU and tricking it to work with the 5 speed trans?
  14. #134
    05-03-2007
    Socal/Central Coast
    3,803
    Quote Originally Posted by shane View Post
    Correct. But depending on your year, you may need the corresponding speed sensor or year of transmission. Also, years 2001-2003 will throw CELs after installing the 5-speed.
  15. #135
    off subject, but now there is more of you 5spd guys, do you think that you should have spend the $ for a lsd?
  16. #136
    09-30-2002
    San Gabriel, CA
    573
    yes its worth it (to me). put in a quaife after 2 years of doing the manual swap, been 3 years since.
    its a significant investment though. it costs as much as doing a 5speed swap by yourself(free labor), and you wont really take advantage of having one, unless you do canyon runs or race every weekend. you also need some decent tires or its worthless, both wheels will just be spinning w/o traction. (which is whats happening to me right now, have yokohama avids, haven't invested in a good set of tires because i haven't put much attention to the car this past year)
    so i guess weigh your benefits carefully.
  17. #137
    09-30-2002
    San Gabriel, CA
    573
    also, dunno if this also helps, maybe this will give you an idea of how much spirited driving i do, mostly canyon runs btw.
    my g eats through a set of summer tires once a year after the manual swap. except last year, when they shut down angeles national forest because california was on fire. thats why i have avids right now, but these aren't lasting very long either.
  18. #138
    05-03-2007
    Socal/Central Coast
    3,803
    Quote Originally Posted by hsinya View Post
    you need to come on a GMR run with us! ah
    btw, did you ever wire up the cruise control? I was thinking about this the other day... as I have been having to drive 2.5 hours straight without it. It'd be nice to have it back lol.
  19. #139
    09-30-2002
    San Gabriel, CA
    573
    i will lol. emerson has been inviting me to all these mini meets and i haven't had the time to go... and also haven't had time to mess with the car. should be having some spare time in the upcoming months in spring. also got some 225/45/17 falken 912's. now i just need to get alignment then i'm good to go lol
    for the cruise control i was thinking of running wires from a switch to the auto tranny socket. lead1=neutral. lead2=drive. ground=gear selector to pcm/ecu.
    i'm not sure how this will affect the ecu though. it doesnt throw the auto tranny solenoid codes in park/neutral... but i wonder if it will throw codes while the gear is set to drive though.... because the ecu is actually trying to shift while in D as opposed to P or N?
    i'll definately put up a post whenever i actually get around to it
  20. #140
    05-03-2007
    Socal/Central Coast
    3,803
    That's actually exactly what I was wondering also. I don't want to screw anything up, so I was hoping someone else already did it :P
    BUT if you only use the cruise control on the highway, the car would never really need to shift anyway.. but then in Drive it might be looking for some kind of voltage across the solenoids, which are non existent.
    I had about the same idea for the switch as well. I could also just leave it in "Drive" when parked, so it would actually be impossible to start the car unless you knew where the switch was.
