Thread: 2G Eclipse catback exhaust compatibility with 7G Galant?
Showing results 1 to 6 of 6
    Someone local to me is selling this:
    For like $300US
    It's pretty much brand new but I'm not sure if this is going to fit onto my International spec E84A Galant VR4
    I know for a fact that the rear gas tank part number shares between my galant and the AWD Eclipse so my guess is that the floorpan is actually the same.
    But I am not too sure, would anyone know for sure?
    07-20-2003
    Orlando, FL
    3,169
    IS the exhaust for a FWD Eclipse or a AWD eclipse? If its for a FWD...its not going to work unless you modify the exhaust routing.
    Also you may have a issue for the front part of the catback since its designed for a 4G63 downpipe and not your 6A12tt downpipe in your VR4.
    Either or...its going to take some modifying of that exhaust to fit your E84A VR4 7g.
    Quote Originally Posted by 4-G-rim View Post
    he says it's for AWD Eclipse. I'm not too worried about the downpipe part because it's a catback.
    The cat sits in the same place for 4G63 and 6A12. The rest is in this package.
    I think we might have something here...
    background: European Mitsubishi Galant AWD with 6G73.
    foreground: Eclipse Turbo AWD exhaust system.
    01-19-2007
    Lyndhurst, NJ
    3,473
    Looks like it should fit.. Just make sure the hangers are the same..
    yeah they all look like they'd line up. Except for #12 but it's only turned 90 degrees should be an easy fix with a different hanger rubber.
