Thread: HELP! Camber kit Install
Showing results 1 to 6 of 6
    TGC Regular
    11-14-2007
    Boothwyn,PA
    719
    Ok so i just had a package delivered today. It is my balljoint camber kit from ebay. Now Is there anyway to install it and one i have it installed does n e one know how i should adjjust it??? The tires are weafring on the outside edge so i believe that it is possitive camber.
    Thanks guys!!
    you will have to remove the brackets from the frame of the car. I ordered mine from summit racing and i couldn;t quite gt it on the other side yet. The washers on the bolts that were supplied to you are designed to adjust for toe in toe out adjustment, but a proper alignment by a professional will definately be needed.... it costs to be lowered:)
    Dc sports Header
    N1 exhaust
    Megan Springs
    Falken ZE512 225/40/18
    18" Motegi DP6
    Cross drilled slotted rotors
    Night shade tail lights
    Cleared Corners
    Next...going in today...
    Dvd Player
    New infinity speakers
    07-20-2003
    Orlando, FL
    3,169
    Are these the SPC camber adjustment ball joints you purchased?
    TGC Regular
    11-14-2007
    Boothwyn,PA
    719
    yes they are.. But it doesnt matter currently. Im having an issue with my distributer. It went and then i replaced it. Well now its not firing correctly. its off for some reason. Not to mention that when i try and start it there is a tremendous load on the starter. When MKO And i were messing with it last night the starter gave out on me. Soo yea this sucks guys. I have to go and take out a car loan to get a DD. 4-G-rim if you have any suggestions on what the problem would be, it would be greatly appriciated.
    12-17-2002
    Sherman Oaks, California
    4,304
    how did you know there was a lot of load on the starter? besides for the fact that it wen't out....any other symptoms?
    http://socallifestyle.com/
    1994 Galant GS 5spd
    TGC Regular
    11-14-2007
    Boothwyn,PA
    719
    it just seemed like the starter was having a tough time like it would crank and then pause for a min like it was strugling and then it would rank it again... then the starter finally went
