Errrr.... if you disable 2 cylinders the car won't idle....
We don't have this problems here, we have no emission laws.
1995 FTO - V6 Mivec 200hp
lol @ disabling cylinders to pass emissions. Have you looked at the O2 sensor(s)? they could be faulty causing the ECU to dump in more fuel. You're definitely using the correct plugs? It could be an injector or two not spraying the fuel in a fine uniform pattern, but instead dribbling the fuel in - this will effect the combustion on that particular cylinder and unburnt fuel could be expelled into the exhaust.
no it's fine I have a narrowband to keep an eye on the O2 I just changed the O2 and it's working perfectly.
The issue with this engine is that there are no EGR or airpump system for the emissions so anything that's burnt or unburnt it's shot into the exhaust.
And the fact that a 1993 car gets a simulated driving test so it has to be perfect in acceleration, holding speed AND deceleration..... The test drives the car up to 100km/h just like the Cali test..... It's a bitch to pass.
I guess that's why those models weren't offered domestically there.
