The cruise rewire is pretty straight forward. Pin 3 on cruise computer has a black wire with a yellow stripe going to it. The same wire is shared with the brake light. Just clip that wire at pin 3, then connect that pin to a normally open switch on the clutch pedal. Run 12V to the input of the switch. When the clutch pedal is up the pin will see 12V, and 0V when it is depressed. There is a 4 pin switch on the brake pedal that is what you need. Just pick up one of those with the harness plug and wire it in. I think I need to wire another pin of the switch ground though because right now when I push my clutch pedal in it doesn't cancel the cruise control. The switch must need to pull that pin to ground to work properly (not really surprising but I wasn't considering that when I wired it).
