Thread: 4g63t / AWD 7g Build
Page 23 of 23 FirstFirst ... 131920212223
Showing results 441 to 445 of 445
  1. #441
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    I may have missed a pm or two. Inbox was full but cleared out now.
  2. #442
    09-06-2008
    533
    Well, the G is stripped down and in the salvage yard. I found a 99 GST Spyder I'm putting the awd system into and building up the 2.4 again. I did save the new engine harness I built and the wideband controller plus dash display. If anyone wants them along with a 2g reflashable ecu let me know. It converts a OBD 1.2 car to OBDII, manual harness and turbo. Uses a '90 CAS instead of the cam and crank sensors.
  3. #443
    What a shame! At least you sticking with the Mitsubishi family
  4. #444
    09-06-2008
    533
    I'm just glad I got to build it and give others the confidence to go ahead with it too. The Spyder will be lots of fun too.
  5. #445
    04-25-2007
    727
    wow, I was thinking of doing the exact same thing Eclipsh :) ! Also need to speak with you about that harness setup!
    Thanks again for answering all those questions on my awd conversion, its been a blast and lots of fun!.
    Check PM.
