Thread: 2000 4g64 kia head timing belt
Showing results 1 to 9 of 9
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    evo belt 153 teeth
    94 galant gs dohc belt 154 teeth
    ive heard the evo belt will work and ive also heard the galant one will work also
    galant dohc belt 1 more tooth? a bit confused
    soon to be done with the engine build thanks in advance
    <a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&amp;current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
    the teeth on the belt shouldnt matter.
    I was told to use the DOHC GS belt due to the EVO belt is from the 2.0 and the DOHC GS belt is from the 2.4.
    With your application, since it is a 2.4L build it would make more sense to use the 2.4L belt than the 2.0 belt.
    Jigz-TGCIL Sosick Motorsports
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    k thanks
    You are still around??? How is the build going?
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    almost done waiting on some gaskets and timing stuff going to order timing gears today
    Member JDM4G64T's Avatar
    07-09-2007
    Fort Lauderdale, FL
    324
    Not bad..... looks good so far, keep it up!!
    Car is sold, no more G.... Moved on to something a big more sporty.... lol
    08-04-2003
    NY
    4,344
    I used the 94 GS belt, Slava and Napalm from c3g used the EVO belt, they both worked, so either way should be fine.
    99' Galant ES
    4G64/63T
    AEM EMS
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    alright stewi i bought the 94 gs belt ive heard of a couple of people running the galant one thanks
    Senior TGC Member lonestar22's Avatar
    01-24-2005
    DFW/Stillwater
    2,752
    i just read about some guys bending valves using the EVO belt. so id use the Galant dohc belt to be safe
