Thread: New Reputation System
Showing results 1 to 10 of 10
    Was installed a few days ago. A members reputation means nothing more then what other members rate their posts at. It may be accurate, it may be far from, its all for fun. To give a member good or bad rep, click the scale in the lower left section of the members post. From there, you can give the member positive or negative rep, and a description why.
    Please do not abuse this, dont give members repeated bad rep just because you do not like them. There are rules in place that prevent you from abusing this.
    It takes one point to give somebody rep. You get 1 rep point for every:
    -3 days that go by
    -10 posts that you make
    -every 5 +/-rep points received by other members
    If you have under 30 posts, reputation you give to other members does not count against their total rep score. You can only give out 5 points per day, and you have to give rep to 5 other people before you can hit the same person again.
    Any questions? Post here.
    Updated the rules a bit so it doesnt take as long to get more rep.
    Also as common courtesy, if somebody helps you out in a thread and answers your question, give them positive rep.
    Gbaby2089
    umm why can't i rep?
    Read the first post, you have to acquire points in order to post.
    Try try try again. Should work now.
    TGC Regular youngin3's Avatar
    04-02-2008
    Dallas, Texas
    642
    Is there going to be a way to see our reputation points in our User CP, similar to other forums? I think it is cool to be able to see how many reps you got, where you got them, who gave them to you, and the messages/reason you got them for.
    Gbaby2089
    Quote Originally Posted by youngin3 View Post
    yeah it showed that i got negged by greddy
    Proto's Minion Jasmine's Avatar
    01-24-2007
    New Zealand
    355
    Aww, I'm an unknown quantity -sulks-
    03-12-2007
    Dallas TEXAS
    2,041
    Lmao!
