Thread: No Sir, my door is not ajar..
Showing results 1 to 4 of 4
    San Antonio, Tex-Mex
    1,413
    My damn door light is on... the one by the gas light. It won't turn off. My doors are not open, neither my trunk nor hood either. I have triple checked everything I can think of:
    Door pins- tell the car when the door is open/shut, seem to be in good condition. I removed them and re-inserted them
    Fuse Box- I don't see a specific fuse for the doors, but the guage fuse is good 2 go
    Gauge cluster- I took it out and gave it a gander, looks good, I would think the bulb would not work rather than stay on all the time if something were wrong there...
    I have no idea what else I should be looking for, my damn doors are CLOSED!! :x
    BTW.. dome light stays on too.
    <-Check it out Maz
    My 7g
    01-10-2003
    BROOKLYN nYC
    1,570
    Try pulling the door sensors out and testing them with a multimeter for contact open and close. One of them probly killed itself somehow and is always reading open. Only thing I can think of.
    Rob
    rIp 97 Galant
    starting over.
    90 Talon
    just pull the bulb to the Ajar light :lauging:
    queball
    you more then likley just have a bad switch on one of your four doors, or one of them have moved and its grounding its self out all the time saying the door is open..
