You can find all of these points with a cheap multi-meter
12 volt ignition means a source that is only on when your key is on. When the key is off, it will read 0 volts
12 volt battery means a source that is constantly 12 volts no matter whether the key is on or off
Chassis ground means a metal point of the chassis that is 0 volts all the time.
