You have to measure the actual width of space you have to start. Here is the method I've used for old school muscle and hotrods for wheel fitment.
#1 - Jack up the car, take of the wheel, and try to have it close to the ride height that you want.
#2 - Using a straight edge measure from the rotor hat up as far as possible (until you reach the closest point).
#3 - Then using a second straight edge measure inside as far as possible (until you hit either the body, or first suspension component.
#4 - Measure outside to the fender lip.
That gives you the actual width you have to work with, excluding cambering affects when the wheel and vehicle is on the ground. After you know the width you subtract about .75" on each side, which gives you enough room for the tire, especially if you want as wide as possible.
Here is a picture that may help. NOTE: The blue lines are the places you need to measure. Also to stress the point, don't forget about the caliper. I'd say your safest bet is to get a EVO caliper and then make a template of it and account for it in your measurements.
