Ive never seen that before, that comes stock?
~Gabe
Edit: Found the answer!!!
I got a SUNVISOR, it comes with the gate opener. Please let me know how I can program this door opener to open my garage door with it?
Thanks,
~Gabe
When I feel like eating a banana, I like to go to the zoo, sucker punch a gorilla and try to run with a banana hanging out my bum. Then if I succeed, I enjoy my victory with said banana and a stroopwaffle.
Yeah its stock on some super rare 8g, however I found my answer.
How do you do it? I have one.. They come in the LS and GTZ model..
Not all LS and GTZ.
1. turn engine off
2. prepare for programming the mutsubishi homelink universal transmitter by erasing all three of the factory defauly channels by holding down the two outside buttons until the red light begins to flash (20-30 seconds). release both buttons.
3. hold the end of your hand-held transmitter against the mitsubishi homelink universal transmitter (located on your visor) keeping the red light red light within the homelink icon view.
4.using both hands, puch the hand-help transmitter button and the desired button to br trained on the mutsubishi homelink universal transmitter. do not release the buttons until step 5 has been compleated.
5. hold down both buttons until the red light on the universal transmitter flashes, first slowly and then rapidly. when the red light flashes rapidly, both buttons may be released.
6. to program the remaining 2 channels follow steps 3 through 5.
NOTE: when sending a code, keep the transmitter within about an inch for the mitsubishi homelink universal transmitter.
Thanks for the quick Tutorial im headed to the JY tomorrow ill see if i can find one
~Gabe
I usually see those garage openers on 3G Eclipse, 2G Stratus/Sebring Coupes.
My 2000 GTZ don't have that... :?
EDIT: just checked CAPS and it was available in 99-01 ES premium and LS models only!
'00 Patriot Red GTZ --> JDM'ed... 5 Speed... ...
is that battery operated? or it connects of the vanity mirror?
I think they were only available in 99 GTZ, LS,and ES V6.
Do u think that this will work on a 2007 galant ralliart? i have been trying to look for this answer for my year but cant find it. the only thing is that my buttons are on my rear view mirror.
It looks like it comes with the homelink opener right? I think the instructions might work from another car. It should be in your owners manual. Do you have it? Otherwise I'll look for the instructions for our Volvo and let you know. I've programmed it for the volvo before, but it did require getting up there into the garage door controller and hitting the program button before it worked. Let me know.
Did you have to do anything in your garage door itself, or did you just try programming your car? Mine didn't reprogram my other openers.
