Thread: Trunk setup question
Showing results 1 to 16 of 16
    Got a question that I hope someone can help me with.
    I have a JL 13w7 in a sealed box pushed by a Kicker ZX750.1 monoblock amp. I believe the amp is a 4 ohm amp, and the sub is a dual 1.5 ohm VC sub. I was wondering what exactly I need to do to get 750 watts through the sub. I got the entire setup from a friend for 500 bux, (sub already in box) so I have no idea how the speaker is wired inside the box. Any help would be awesome, I hear you have to run your speaker wiring a certain way to get full power from the amp. Thanks guys. -Arty
    2002 Mits Galant ES
    Check it out.
    http://www.myspace.com/shaft101
    04-01-2008
    Tempe, Arizona
    1,996
    Amps cant be 2 or 4 Ohms. They produce different amounts of power when the sub is 2 or 4 ohms. So if the sub is 2 ohm your amp will be shooting out 750 watts rms, and if its 4 ohm it would be lower. Cruthfield has wiring diagrams so you can get your specific diagram to see how to wire the sub.
    http://www.crutchfield.com/S-oe7cQQk...rs_wiring.html
    04-01-2008
    Tempe, Arizona
    1,996
    Since your sub is dual 1.5 ohm I would suggest just wiring it the same as dual 2 ohm. I just would be worried that it would damage your amp because some amps are not stable at anything less than 2 ohm.
    So the only way to wind out would be to pull the sub and take a look?
    2002 Mits Galant ES
    Check it out.
    04-01-2008
    Tempe, Arizona
    1,996
    off the top of my head I think that those JL sub/box combo's are wired to a single 3 ohm load.
    Yes the final load is 3 ohm. http://www.sonicelectronix.com/item_...S113RG-W7.html
    So just wire up the sub normally, and you will be pushing close to the full RMS capability of your amp.
    Can you explain what the "sub-sonic" switch does and if its good or bad?
    http://www.sonicelectronix.com/pictures.php?id=6595
    2002 Mits Galant ES
    Check it out.
    04-01-2008
    Tempe, Arizona
    1,996
    i believe it will filter the sound so that only frequencies above 25hz will play, but im not 100% on that. I would put it on, and then turn it off. Listen to how it sounds and see which one you like. You sub will have no problems hitting any note you throw at it so it depends on what you like better
    Well, it looks like I can only wire for 3, or 1.5 ohms. At 3, I will make roughly 560Watts. If I wire 1.5 ohms, the amp will shutdown. I wonder if I could find a 750 Watt amp that is 1.5 or 1 ohm stable......
    2002 Mits Galant ES
    Check it out.
    04-01-2008
    Tempe, Arizona
    1,996
    all JL audio amps are stable at 1-4 ohm. you can get a 500.1 or a 1000.1 and it will work with your sub. just look at sonicelectronix and see which amps are capable at 1 ohm, if they say they are then they will be able to handle 1.5 ohm as well. i hope i helped
    04-01-2008
    Tempe, Arizona
    1,996
    here is JL audios version of the 750.1, capable of handling 1.5 ohm - 4 ohm. Its pricey but it will get the job done.
    http://www.sonicelectronix.com/item_...o+HD750-1.html
    look at a hifonics amp. you can get one 1200x1 @ 1 ohm for under $250
    Quote Originally Posted by chickenlegsyo View Post
    Hifonics arnt bad, if i where going to get another amp i would be getting a Rockford. They have some really nice amps for the price.
    And a random WI member.
    1996 galant s
    if that amp is not capable of running @1 ohm stable or lower you will not be able to use this amp if you run that sub @ a 2 or 4 ohm load you will blow it quick. if you go on the jl web site it will give you a ohm calculator hope this helps.
    http://mobile.jlaudio.com/support_pages.php?page_id=161
    that is the link
    this is why i never went with the w7 i like my old school mtx amp the runs at 4ohms
    just to throw it out there im pretty sure that your "friend" may have ripped you off, you could have gotten a nicer system for the same price or cheaper is that a 15?
    ~Gabe
    When I feel like eating a banana, I like to go to the zoo, sucker punch a gorilla and try to run with a banana hanging out my bum. Then if I succeed, I enjoy my victory with said banana and a stroopwaffle.
    its a 13.5 inch speaker, but it compares to 15s
    2002 Mits Galant ES
    Check it out.
    04-01-2008
    Tempe, Arizona
    1,996
    Quote Originally Posted by therev View Post
    ~Gabe
    he did not get ripped off dude, JL audio is expensive. This is his sub and box for 1150 from crutchfield.
    http://www.crutchfield.com/p_136S113...JL+audio+13+W7
