Thread: 8g AWD..Half way done.
Page 3 of 7 FirstFirst 1234567 LastLast
Showing results 41 to 60 of 133
  1. #41
    Quote Originally Posted by Serstylz2 View Post
    my AWD Galant is halfway done too.
    Its FWD.
    im cryin dude. thats hilarious.
    Cali your amazing,
    I became insane, with long intervals of horrible sanity.
  2. #42
  3. #43
    05-01-2008
    Manitoba
    1,589
    Cali's busy doing engine swap for Matt..
    Tuned 2013 Evolution X GSR PB
  4. #44
    08-04-2003
    NY
    4,344
    Quote Originally Posted by Galante View Post
    and making me custom parts....Muhahahaha!
    99' Galant ES
    4G64/63T
    AEM EMS
  5. #45
    Nice, cant wait to see this done. Theres a guy that has been doing this on club3g on his Black RS, but i dont think he has finished his yet either.
    02StratusRT and 00EclipseGT
  6. #46
    sorry to revive the thread, but has there been any progress on this? it looks great so far
  7. #47
    none whatsoever...been busy doing other projects..i'm barely in the process of fitting the new drivetrain in the starion and after that im restoring a '67 fairlady i just picked up.
    in mean time im just driving it the way it is everyday.
    Cali: Sig 3/28/2011
  8. #48
    05-02-2008
    Hacienda Heights, CA
    3,014
    cant wait to see finished product, good luck
  9. #49
    i took a look under the car w/ CALI at MOD09... it's all there, axles, AWD tank, AWD rear cross member, rerouted exhaust and all! if i recall, it just needs a driveshaft and AWD tranny, then it works. it's pretty much done!
  10. #50
    Lets hope its gettin easyer soon over here in Norway to get custom building as that legal :( I want AWD :(
  11. #51
    08-04-2003
    NY
    4,344
    LOL
    It needs alot more than that. It needs EVO knuckles, EVO front axles, a transfer case, a shit load of cutting and reinforcing the front subframe, cutting the firewall, relocating the steering rack and re-routing the lines and another PITA mounting the driveshaft. If I recally correctly you would need to source the carrier bearing assemblies from a wrecked EVO and the mounts. The mounts are not sold, so you need a wrecked EVO and you need to drill out the mounts from the bottom, shim them correctly and weld them onto the 8g floor pan. Im gonna be able to give Noel some help on this one, because if all goes as planned, this time next year I will be doing the swap as well, that is, if I dont get the time I want running it FWD.
    99' Galant ES
    4G64/63T
    AEM EMS
  12. #52
    Member krow's Avatar
    01-22-2009
    Baton Rouge, La
    325
    God thats a lot of work.
  13. #53
    blah it's not that bad. :)
    brian is right though there's more details to it. more than likely though i will be running a tubular front crossmember to help with the space issues.
    whenever that is lol.
    Cali: Sig 3/28/2011
  14. #54
    08-04-2003
    NY
    4,344
    Quote Originally Posted by Cali View Post
    Yeah when I get mine made I will have them make a 2nd one for you. It will take alot of the guess work out. over the winter im gonna go to the junkyard with a sawzall and find a bare 8g shell with no front crossmember before it gets crushed I wanna go to town cutting up the firewall and see how many layers their are on the center and how thick each one is. In hindsight i wish I though of that before you got rid of the white car.
    99' Galant ES
    4G64/63T
    AEM EMS
  15. #55
    hey brian i wonder if we could get away with taking the BFH to it instead of cutting up the firewall....how much clearance are we talking about? 2-3 in?
    it worked on the starion lol.
    Cali: Sig 3/28/2011
  16. #56
    No,
    i'm certainly positive it would require a RBFH.
  17. #57
    08-04-2003
    NY
    4,344
    HAHAHAHAHA...thats so gangsta....
    Honestly, the part of the firewall that needs to be cut im pretty sure is about 3 or 4 seperate layers, so even a RBFH isnt gonna do much, maybe if you put the car on a jig and turned it upside down so you could swing like a lumber jack, there may be a chance, but im gonna lean towards no. We are probably taking about 4" or so.
    99' Galant ES
    4G64/63T
    AEM EMS
  18. #58
    01-22-2009
    Baton Rouge, La
    325
    Has this been done before on a Galant? Its going to be cool when there is a blueprint for doing this.
  19. #59
    08-04-2003
    NY
    4,344
    It hasnt been done yet, but im sure in the next year either Noel or myself will make it happen.
    99' Galant ES
    4G64/63T
    AEM EMS
  20. #60
    Any updates??? I'd like to do this also but won't try it any time soon cause I have no time...
