Thread: what block build would be the best outcome?
Page 2 of 2 FirstFirst 12
Showing results 21 to 32 of 32
    08-04-2003
    NY
    4,344
    Quote Originally Posted by Blue8G View Post
    can you do an awd/5 sp swap when keeping the 4g64 block, sorry i'm a newb when it comes to mitsus and awd/trans/engine swaps..
    Do you mean leaving the stock 4G64 motor and going awd? It would work but the car would be a slug, more driveline loss due to the awd conversion with no added power from the engine.
    If you mean does the 4G64 block physically bolt up to the awd trans, well the answer to that is yes as well.
    99' Galant ES
    4G64/63T
    AEM EMS
    TGC Regular Boosted's Avatar
    12-03-2008
    Fayetteville, NC
    575
    The only AWD donors would be an Evo or an Eclipse GSX. You can use the 3G transmission as long as it isn't for the V6. If you are running that transmission you can keep the 4G64 block.
    08-04-2003
    NY
    4,344
    Quote Originally Posted by Boosted View Post
    No.
    The only awd trans donor would be an EVO, the 2g GSX trans will not work for an 8g.
    99' Galant ES
    4G64/63T
    AEM EMS
    12-03-2008
    Fayetteville, NC
    575
    I am not talking about the transmission when I said donors. I was talking about the rear end.
    blue8g
    alright i was talkin about the 4g64 block, but i will do the dohc swap and turbo it too, before i do the awd stuff
    ok ok stupid question... is there anyway that a 3G eclipse tranny can work with an AWD set up.. or do i have to look for an evo one?
    if i have the evo tranny the rear 2g GSX rear end would work with that?
    can the evo 9 mr 6 speed work with are galants?
    08-04-2003
    NY
    4,344
    Quote Originally Posted by Gtorque View Post
    6 speed EVO trannies are nightmares, even EVO guys hate them. They are weak, parts are hard to find and nobody really really rebuilts them right.
    You cannot make a 3g tranny awd.
    Also in terms of the rear end you should get a 2g AUTOMATIC GSX rear end, the manual rear end is not the same gear ratio as the EVO transfer case outputs so using anything else will lead to problems because the front wheels and rear wheels will spin at different speeds.
    99' Galant ES
    4G64/63T
    AEM EMS
    good to know man
    so in order to do this swap i need the evo transfer case to right?
    sorry... dont know to much about trannys
    08-04-2004
    Westchester NY
    1,332
    o boy..
    05-24-2005
    Greensboro, NC
    494
    You need the entire evo transmission. Like he said before you cant make the 3G transmission awd.
    ^ i know that... i was talking about the 2g GSX rear end
    08-04-2003
    NY
    4,344
    Yes EVO transfer case
    99' Galant ES
    4G64/63T
    AEM EMS
