Thread: Need some info. My rear Wheels are Butterfly
Showing results 1 to 18 of 18
    I dropped my Galant with Work springs in Jan. Im not sure if i had this problem before i dropped it, but my Rear Wheels are Butterfly. I went to a Alignment on my wheels. When they came back with the car i was told and shown that my rear wheels were butterfly in the rear. Ive been asking around and i was told if i put on a camber kit it would fix it. Can any one give me any ideas or give me some info on a good camber kid that would fix my wheels. Thanks...
    Member Rayth's Avatar
    06-02-2008
    North Shore, Boston MA
    344
    check with Ingalls.. the WORKs dont drop you all that much so those should work well.. Import Car Parts Plus sells them and you should also be able to find them on ebay
    Quote Originally Posted by Rayth View Post
    Thanks. I found these.
    http://www.ingallseng.com/mmy.php?ye...t=Camber%20Kit
    Would these work on my Galant? And if they do which are the best ones?
    Baltimore, MD
    2,848
    Quote Originally Posted by LosAngelesRider View Post
    Yep they'll work on the galant. Check the specs they gave you with your alignment and find out how far your camber is out in the rear. If it's more than +/- 1 degree you have to get the larger kit.
    Chip
    (Paint Code: Porsche LC9Z)
    11-05-2003
    San Francisco Bay Area
    1,517
    I gave him that link, but didn't realize he had a 9G - don't know if the 8G camber kit fit the 9G
    hey i saw the paper on my shield yesterday lol where did u see me? are u needing the rear kit asap? i have the box with the size and everything but its back at fontana and not comming back there till next week...
    ill try calling and get u the info u need, i believe its a 12mm camber bolt in the rear from a mirage, thats what im using in the back. ill get back at you later
    ^^ the link above will not work...its more for 7 and 8g rear. the front for sure are 16mm camber bolts. its the exact same ones as the 8g front bolts
    uhhhh...... Whats a 9g???
    okay just got off the phone... its 12mm fast cam bolts for the rear
    Quote Originally Posted by krazienluv10 View Post
    Thanks. Yeah I was gonna go eat at Dennys when i saw your Galant. I need that Kit ASAP. Where did you get your kit from. I have no idea what to do. My tires are all jacked up. I didnt know i needed the kit when i lowered my car.
    its like those, but those are for the front, rear are different size. its the bolt right behind the brake shield (upper control arm) number 11 i believe on the diagram.
    OK... I bought Ingalls Fastcam Bolts. Front 16mm 81280 and Rear 12mm 81250. I hope i got the right ones. I paid $50 something Bucks for them...
    I dont have any idea where the rear one go? Any ideas?
    I also have some R1 cross, drilled,slotted rotors and works rear swaybar...
    replied on gf
    05-31-2005
    4,735
    ^oww i wanted to know too.
    06-02-2008
    344
    let me know if those are the right ones i just got my WORKs in and i'm gonna pick up the camber bolts very soon
    Did the rear sway make a big differance?
    it goes near the break dust shield... if you look straight at your rear rotors theirs a bolt at the 12 oclock postion behind the shield. thats where it goes. the place ur pointing at i believe changes the toe. Reply from GF.
    I'm not sure if it makes a difference yet. The swaybar that is. I'll let you know once I get my camber kit put on...
