Thread: 92 Galant
Showing results 1 to 5 of 5
    02-18-2009
    NEWBURGH, NEW YORK
    486
    92 Galant
    I currlenty own a 1992 galant. sohc .4g63 rulez. for your infomation. It has 200785 miles on it. i just put a new clutch set in. I allready did
    Alternator
    Battery
    Head Lights
    Timing Belt
    Spark Plug/Wires
    Keep up on my oil changes.
    raditor hoses
    what else should i do. It has good tires and brakes.Its quiet for a high miles car. i bought it in october at 192202 miles and never really had a problem and want to keep it that way and keep the car for a long time.The car body is in very good shape. minor scarthes and small dent. I heard people get more miles out of this 4g63 motor. i would like to be another one of those owners.
    07-20-2003
    Orlando, FL
    3,169
    When you did your timing belt did you change your water pump along with the tensioner pulley, idler pulley, crank seal, cam seal, oil pump seal?
    Is it a automatic or manual?
    6g's are well built cars...very solid.
    02-18-2009
    NEWBURGH, NEW YORK
    486
    manual. i only did the belts. every thing else looks good. i want to do my pvc patch a few very small holes on my trunk because of that metal spoiler cargo carrier on top of my trunk .and it has a new clutch set as of friday and alternator /battery as of this afternoon.
    07-20-2003
    Orlando, FL
    3,169
    Well the car should run for many years more. Not sure if you replaced the water pump..but if you didnt its probably a good time to do it or at least should of be done when the Tbelt was done.
    02-18-2009
    NEWBURGH, NEW YORK
    486
    that what im hoping for. r u going to the pa meet on the 26 of april in valley forge
