You mean 'evacuted and recycled', technically the same as 'vacuumed'. You have to have an A/C Charge and Evac machine to do it. You can buy a R-134a recharge kit that should most likely be sufficient to cure your problem. Personally, I would say if you were mechanically inclined enough to replace the a/c condenser the a/c recharge should be easy also.
