Thread: AGX shocks my Galant look taller?
Showing results 1 to 20 of 27
    New Member USMCSKYLINE's Avatar
    04-01-2009
    Florin Rd, Sacramento, California
    55
    I just wanted to ask , did I do something wrong?
    I installed my new Tein springs I received yesterday and my car sits up really high now...it doesn't look like I have lowering springs. So far I only installed the back shocks but would that be it?
    I didnt know they made AGX springs??
    Jigz-TGCIL Sosick Motorsports
    09-10-2003
    Charlotte, NC
    4,463
    Its probably because your old struts were blown, and now that you have good struts its sitting at the proper height now with the springs
    04-01-2009
    55
    oops...fixed...no but I'm using Tein Springs and when I installed them it gave me the drop I was supposed to get. 1.7 up front & 1.3 on back. Now When I installed the agx shocks my back side is sitting really high...more than it did when it was stock. Kinda looks like I went 4x4!
    Quote Originally Posted by USMCSKYLINE View Post
    did you unstrap the shock before you installed the spring onto it?
    do the front and then you can judge if its lowered or not
    That will happen since your switching from stock. Read this thread, a few ppl said that happened to them also.
    https://www.thegalantcenter.org/show...=installed+agx
    2001 5 speed 4g64T
    04-01-2009
    55
    oh men that sucks...I did noticed however that when I drove my car the back did get low again...not as much as it was before but it did get low.
    RadRICH - TGC Founder BGR's Avatar
    12-09-1999
    FLORIN - Sacramento, CA
    1,996
    I had SMA install my KYB & springs for $150 out the door on the Galant.
    Superb Auto Repair Smog & Tire Center‎ on Florin did the struts and springs on my Sentra for $350 out the door with alignment.
    01-08-2008
    Levittown NY
    2,786
    I did mine for free then 60 buck alignment
    you old shocks were probably blown, that would also explain the bounciness. when you put fresh ones in, they are now sitting at the correct height
    Bronx NYC (reppin)
    3,489
    I just happened to got my hands on some rear 2G Agx's if you need anything holla
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    the struts dont affect the ride height tho, atleast they shouldnt. its the springs that determine the height. thats why they make lowering springs and not lowering struts. are you sure that the struts are compressing and they arent stuck decompressed.
    I became insane, with long intervals of horrible sanity.
    It happened to me. I used to hit the curb when parking at the local Starbucks, after I installed the AGX my bumper clears it no problem, also my wheels look smaller since the GAP is somewhat back.
    10-24-2003
    1,432
    Unless the strut is seized it should not effect ride height, in fact there is no way it can effect it. My JIC mono tube dampers can be compressed by hand even though there is 300 ish psi of nitrogen pressure on the fluid.
    The reason why many vehicles appear to be at a higher ride height after they have been worked on is because when you let the vehicle down after being up on a jack the tire has to move outward a small amount to compress the suspension. When the vehicle is lowered off a jack it will bind against the tires and not settle to actual ride height until it moves, which allows the tires to move outward that small amount to compress the suspension completely.
    www.gooichimotorsports.com
    04-01-2009
    55
    I installed the front ones today and it looks tall, same way it did when I had the old springs. I gotta say though I don't bounce at all which is a big plus but if I knew I was gonna have the same ride height...I would have just left my the stock springs & shocks. I would have save myself all that money.
    Experienced TGC Member AVERAGE's Avatar
    02-09-2006
    Raleigh,NC USA
    1,085
    Give your suspension a chance to settle.
    sighs, the suspension doesnt need to settle, its not the suspension not being not fully compressed and its not the fact that you did anything wrong. its simply that the AGX's are valved completely different and better than the stockers and dont allow for your vehicle to make them compress as much. especially with the tein's. i had this same setup for over a year almost and it never came down from when i installed them. the AGX's and teins are a hell of a combination and work very well to aid the car's rotation in transitions and even long sweepers. the only way you will have a lowered look with AGX's is if you do something silly and cut your springs, blow all four of the shocks, or get the progress springs for the galant. if you can get used to the ride height and actually track the car, it wont bother you as much as it does now. or at least it didnt bother me after i saw how well the car handled with this combo. congrats on a good setup too btw.
    12-09-1999
    1,996
    Glad I never got the AGX's now.
    01-08-2008
    Levittown NY
    2,786
    You say you just got tein springs. Where did you get them are they authentic because i'll show you before with my stock springs and struts and after with my teins and gr2s
    my old sig:
    New ride height of front:
    Street height
    Wheel Gaps after being jacked up and u can see what it looks like after they sat from my sig pics:
    If its heigher then that then your AGXs are dialed in wrong or your springs may not be authentic. How big were the springs next to your stock ones?
