Thread: 94 ES: Check Engine.
Showing results 1 to 3 of 3
    pythonito
    Hi..
    I have 94 Galant ES w/ 128K and a "Check Engine" staring me in the face. I've taken the car to Autozone, but apparently they can only check 96 or newer Mits.. I found a way to determine the code with a Honda Civic online, but I've been unable to find anything for my Galant.
    Any ideas?
    01-10-2003
    BROOKLYN nYC
    1,570
    Hopefully someone else posts a response to this, I remember there was a year where you could read the code by turning the key from ACC to Start back and forth 3 times, the CE light will flash out the error code then. But I dont remember what year or exactly how to do it, or maybe it was an eclipse not galant.
    Rob
    rIp 97 Galant
    starting over.
    90 Talon
    you either need a generic scan tool, or the better way is to use the Mistu scan tool.
    theyre the only ways that will be of any help.
