Thread: 8g Wont Crank with new belts
Showing results 1 to 7 of 7
    Replaced all belts and made sure everything was lined up TDC. Only get a whining at cranking and have no clue what else to do. Someone help
    New Member DaveMitsubishi's Avatar
    04-03-2009
    new york city queens
    65
    you only get whining like the spark plugs aren't sparking? thats kinda whine? or your getting spark but its more whine and sometimes you hear a combustion?
    it gives off a small combust but thats it other than the whining. About to recheck the current timing on it now
    04-03-2009
    65
    yeah if it combusts here and there, its usually timing i've had the same issue after we built my friends 1.6L corolla re did the timing 2 times and it started up after
    From one thing to another. got it up and running....somewhat. Took it for a test ride. Idles at aorund 500 and cuts off when stopped. Going to bite the bullet and take it in to the shop for a tune up and adjustment tomorrow
    04-03-2009
    65
    bad coil pack? if your an i4 that is or bad Dizzy if your a v6 maybe,
    Quote Originally Posted by 40Cal View Post
    By all belts you mean the T-belt, or just the drive/acces. belts?
