Thread: Kia head vs. Evo head?
Showing results 1 to 20 of 32
    jlfisher360
    Ive searched around for some tips, but I cant seem to find an answer to this question. Which DOHC swap would give better HP, a Kia head swap or an Evo head swap?
    Kia has a 56cc combustion chamber, and evo has a 43cc. So with kia you'll need custom pistons to get the right compression that you desire.
    Banned
    06-07-2008
    Orlando FLAWDA
    533
    ^so basicaly, what you're saying is that the Evo head is simpler to do the swap in the sense that you are not forced to have to buy '"custom pistons" if you dont desire to do so. correct?
    and the evo head being 43cc is already the ideal option?
    01-24-2005
    DFW/Stillwater
    2,752
    well you dont HAVE to buy custom pistons, but it doesnt hurt if u plan on making gobs of power
    Banned
    06-07-2008
    Orlando FLAWDA
    533
    true, but you can still make "gobs of power" with the stock OEM evo pistons. And money can be better spent on actual power adders like cams, fuel injectors, TB, etc.
    You are gonna need custom pistons wither way. You can't use stock evo one because they are smaller, but you won't need to make custom custom ones either.
    evo is 85.5 bore, galant is 86.5mm bore. And you'd need to go .020" over to cleanup the cyl walls anyway. so you need new pistons to be 87mm. Now when you order pistons for the evo head you can actually pick out an evo part number and tell them you need them in 87mm diameter. But with HY/KIA heads you will need to figure out the dish size, valve pockets, stroke, compression and hope thats exactly what you'll get. Basicly to get the evo one it will be at least $125 cheaper.
    blue8g
    if you run the kia/hyundai head you'll be at 8/9:1 compression evo head will be like 11:1, if i remember right....
    Banned
    06-07-2008
    Orlando FLAWDA
    533
    Goosey, i realized where you were going with your initial post. so i deleted my post prior to reading your latest one. but yeah, continue on w/ the thread..
    blue8g
    i think you can run stock pistons, they'll just have messed compression, right???
    08-04-2004
    Westchester NY
    1,332
    i dont think with just a head swap your going to have GOBS OF POWER either way.. try boosting ur car insted
    Banned
    06-07-2008
    Orlando FLAWDA
    533
    Quote Originally Posted by ZigenScarface View Post
    uh.....dude......that kinda' goes without saying. we are just talking about the actual Head swaps here. not the entire engine build.
    blue8g
    what parts besides the head are necessary for the swap??
    NEVERMIND FIGURED IT OUT
    jlfisher360
    Im trying to search some salvage yards around my house here in NC. What year would the evo have to be in order to fit?
    blue8g
    i think it just has to be any evo VIII right???
    jlfisher360
    Thats what im thinking cause just about everyone on here and club 3g says evo 8, but once in a while someone says evo 6s and 7s. And I looked on ebay and found a kia head for about 399, but cant seem to find any evo heads cept through google, and theyre about 1299. Im still gonna go with the Evo head though because it seems to me like you get more for your money outta the evo head than the kia head.
    blue8g
    i plan on using the kia head....
    08-04-2003
    NY
    4,344
    Any EVO 8 head will work. The JDM EVO 4-7 heads will fit too, but you would need all their other BS too, intake mani (I think its different) thermostat housing, water pipe, etc I know those are different.
    99' Galant ES
    4G64/63T
    AEM EMS
    basicly this info has been discussed way tooo many times. Please search club3g if you want to know EEverything
    TGC Regular Boosted's Avatar
    12-03-2008
    Fayetteville, NC
    575
    Quote Originally Posted by jlfisher360 View Post
    The Optima/Sonata head can run as low as $200 through www.car-part.com. Evo heads are good, but the Sonata can build as much power IMO. Just look at the Sonata-powered Evo 9 on www.toplevelperformance.net.
