Thread: p chip without any mods yes or no?
Showing results 1 to 6 of 6
    galantman
    can u use a p chip without any mods?
    you can...waste of money. you will see more gains by using the 400 or so dollars for the chip in an intake or some exhaust parts than you would for a chip.
    Black2k1GTZ
    A chip is usually the last mod you want to do to be able to tie all the mods you have together. It will allow you to change a number of different things to get the most out of your mods!!!!
    Marc :mg:
    J. T. Z.
    Would a chip with headers, CAI, and exhaust give any significant gains or is it still a waste of money? Also, how would the chip help the other components to perform better?
    <div class='quotetop'>QUOTE(J. T. Z.)</div><div class='quotemain'>Would a chip with headers, CAI, and exhaust give any significant gains or is it still a waste of money? Also, how would the chip help the other components to perform better?</div>
    for the price of a chip might i suggest getting an AFC. i mean the chip is tuned to get the most out of your mods and yea if you get more, your not getting the full potential of the chip, at least with an AFC or something else that u can control, you can change things as u go...
    Black2k1GTZ
    A chip is the last thing you should do...after you are satisfied with all the mods you have on your car...then put the chip on to squeeze those last few ponies out of the engine!!!
    Marc :mg:
